[gelöst] Problem beim Erstellen der Firmware
Gayson
5 Sep 2006
Hallo!
Ich bin nun beim Schritt "make" (Schritt 6 in der Anleitung http://wiki.ip-phone-forum.de/software:ds-mod:installation#linux) angelangt, und bekomme folgende Fehlermeldung:
tar -C source  -xjf tools/source/find-squashfs.tar.bz2
tar: find-squashfs/Makefile: time stamp 2006-01-13 23:41:25 is 221871718.710931 s in the future
tar: find-squashfs/find-squashfs.c: time stamp 2006-04-29 20:52:50 is 231016403.704289 s in the future
tar: find-squashfs: time stamp 2006-04-29 20:53:18 is 231016431.699598 s in the future
touch source/find-squashfs/.unpacked
make CC="gcc" LD="ld -static" \
        -C source/find-squashfs
make[1]: Entering directory `/public/ds-0.2.9/source/find-squashfs'
gcc -W -Wall -O2   -c -o find-squashfs.o find-squashfs.c
gcc -o find-squashfs find-squashfs.o
make[1]: Leaving directory `/public/ds-0.2.9/source/find-squashfs'
cp source/find-squashfs/find-squashfs tools/find-squashfs
unzip -q dl/lzma406.zip -d source/lzma406
chmod -R +w source/lzma406
dos2unix source/lzma406/SRC/7zip/Compress/LZMA/LZMADecoder.*
for i in tools/make/patches/*.lzma.patch; do \
        patch -d source/lzma406 -p0 < $i; \
done
patching file SRC/7zip/Compress/LZMA/LZMADecoder.cpp
patching file SRC/7zip/Compress/LZMA/LZMADecoder.h
patching file SRC/7zip/Compress/LZMA_Lib/makefile
patching file SRC/7zip/Compress/LZMA_Lib/ZLib.cpp
touch source/lzma406/.unpacked
make CXX="g++ -O3 -Wall" AR="ar" \
        -C source/lzma406/SRC/7zip/Compress/LZMA_Lib
make[1]: Entering directory `/public/ds-0.2.9/source/lzma406/SRC/7zip/Compress/LZMA_Lib'
g++ -O3 -Wall -c ZLib.cpp
In file included from ZLib.cpp:41:
../LZMA/LZMADecoder.h:189: unterminated macro call
../LZMA/LZMADecoder.h:3: unterminated `#if' conditional
In file included from ZLib.cpp:42:
../LZMA/LZMAEncoder.h:375: unterminated macro call
../LZMA/LZMAEncoder.h:3: unterminated `#if' conditional
ZLib.cpp:58: unterminated macro call
make[1]: *** [ZLib.o] Error 1
make[1]: Leaving directory `/public/ds-0.2.9/source/lzma406/SRC/7zip/Compress/LZMA_Lib'
make: *** [source/lzma406/SRC/7zip/Compress/LZMA_Lib/liblzma.a] Error 2
Keine Ahnung, ob es daran liegen kann, aber da ich auf meinem Eisfair-Server kein dos2unix habe, sondern nur dtou, habe ich einen Softlink dos2unix auf dtou angelegt...
Danke für eure Hilfe!!
also ich konnte das Problem umgehen, indem ich das ganze mit Hilfe einer Cygwin-Installation durchgeführt habe, was wunderbar geklappt hat...
sei so nett und bearbeite den ersten beitrag dieses threads: spendiere ein "[gelöst]" im titel :rolleyes:
holh-66
