[Gelöst] Problem Flashing 7170SL
inshar_it
17 Feb 2006
Hi to everyone!
I am having troubles flashing 7170 FW modded with DS15.2 (or 15.1) on Fritz 7170SL !
It is very strange i have tried on both models, on 7170 it goes well and no troubles in the upgrade, but when i use the same FW file on the 7170SL it doesn't accept the upgrade (also if i force it) and apperas me again the mask in witch the box asks for the file...
Moreover the 7170SL is modded with standard 7170 FW and on the main menu it says 7170... not SL.
Moreover the strange is that if i mod the firmware with DS_MOD 14.4, the new FW goes well on 7170 and on 7170SL
The FW i am trying to upgrade is the last version of the Experimental VPN.
Thanks in advance if someone is able to help me!:)
Do the boxes have the same OEM?
Can you execute /var/install manually after the update fails and provide us the output?
Greets Oliver
Oh Thanks! I was loosing the head for a so stupid thing!
In true i do not understand well german so i did't understood that AVM,AVME,1&1 etc were for reason of compatibility...
Now it works without troubles!
May I mark your problem as solved and close the thread, then?
Protonator
