[Gelöst/solved] telnet running but it is disabled in ds mod?
flemse
14 Mrz 2007
7140 ds-mod fw x.x.33
In ds mod the status is running but the automatic start up is disabled?
I made a clean rescue with avm exe. Telnet is not running.
I now udload the ds mod image. Telnet is not running.
Starting telnet first time for config ds mod.
Reboot. Telnet is not running.
Upload my saved var_flash.tar.gz
Reboot – Telnet is now running??
What config file can enable this. Because the status from ds mod web is manually startup, but the service start automatic.
<Yes I know I can start from scratch and enter all information one more time… but if I can solve it in some config file it will be nice>
Any hints
Flemming.
There is a setting which saves the state for the AVM feature that you can enable telnetd via telephone (the daemon telefon does that). So you just want to disable telnetd by "#96*8*".
Protonator
