[gelöst]voipd crashed
volvic-trinker
5 Aug 2005
Seit dem Upgade auf 86er-Firmware funktioniert die VOIP-Telefonie nicht mehr (s. Quote bzw. syslog.txt).
Nov 2 11:28:44 fritz syslog.info syslogd started: BusyBox v1.17.3
Nov 2 11:28:44 fritz user.notice kernel: klogd started: BusyBox v1.17.3 (2010-11-01 22:31:48 CET)
Nov 2 11:30:20 fritz daemon.info callmonitor: [1] event detected:
Nov 2 11:30:20 fritz daemon.info callmonitor: EVENT=out:request
Nov 2 11:30:20 fritz daemon.info callmonitor: SOURCE='xxxxxx'
Nov 2 11:30:20 fritz daemon.info callmonitor: DEST='yyyyyyyyyyy'
Nov 2 11:30:22 fritz user.err voipd[1745]: 2010-11-02 11:30:22(1) [Segmentation fault] voipd(1745) CRASHED at memcpy+0x114 (/lib/libc.so.0 at 00031f34) accessing _DYNAMIC_LINKING+0x15 (voipd at 00000016)
Nov 2 11:30:22 fritz user.err voipd[1745]: ze: 00000000 at: 1000ce01 v0: 2af85a00 v1: 2ae0e000
Nov 2 11:30:22 fritz user.err voipd[1745]: a0: 2af85a00 a1: 00000016 a2: 000001e0 a3: 000001f6
Nov 2 11:30:22 fritz user.err voipd[1745]: t0: 00000000 t1: ffffffea t2: 00000000 t3: 000004e5
Nov 2 11:30:22 fritz user.err voipd[1745]: t4: 00000000 t5: 00000001 t6: 2ae16f5d t7: 2ab2c322
Nov 2 11:30:22 fritz user.err voipd[1745]: s0: 000001e0 s1: 000000f0 s2: 2aab2380 s3: 000000f0
Nov 2 11:30:22 fritz user.err voipd[1745]: s4: 00000016 s5: 00000008 s6: 2ab2e6c4 s7: 2af0e050
Nov 2 11:30:22 fritz user.err voipd[1745]: t8: 2ae155b8 t9: 2ae3fe20 k0: 00000197 k1: 00000000
Nov 2 11:30:22 fritz user.err voipd[1745]: gp: 2aac5010 sp: 7faf9648 fp: 7faf9828 ra: 2ab2e90c
Nov 2 11:30:22 fritz user.err voipd[1745]: Code: 30c80003 00c83823 00e53821 <98a90000> 88a90003 24840004 24a50004 14a7fffb ac89fffc
Nov 2 11:30:22 fritz user.err voipd[1745]: [bt] Number of functions: 7
Nov 2 11:30:22 fritz user.err voipd[1745]: [bt] (audiocodecmap_pt_is_codec+0x7e8)+0x1f8 (/lib/librtpstream.so.2 at 0000370c)
Nov 2 11:30:22 fritz user.err voipd[1745]: [bt] rtpsession_send_audio+0xb0 (/lib/librtpstream.so.2 at 00008140)
Nov 2 11:30:22 fritz user.err voipd[1745]: [bt] capiconn_inject+0xca8 (voipd at 00415964)
Nov 2 11:30:22 fritz user.err voipd[1745]: [bt] (sip_rtpstat+0x340)+0x4c (voipd at 0040cee8)
Nov 2 11:30:22 fritz user.err voipd[1745]: [bt] (csock_abort+0x10a8)+0x68 (/lib/libavmcsock.so.2 at 0002ac78)
Nov 2 11:30:22 fritz user.err voipd[1745]: [bt] csock_select_with_timeval+0x444 (/lib/libavmcsock.so.2 at 0002b470)
Nov 2 11:30:22 fritz user.err voipd[1745]: [bt] main+0x1098 (voipd at 00411c8c)
Nov 2 11:30:22 fritz daemon.info callmonitor: [2] event detected:
Nov 2 11:30:22 fritz daemon.info callmonitor: EVENT=out:cancel
Nov 2 11:30:22 fritz daemon.info callmonitor: SOURCE='xxxxxx'
Nov 2 11:30:22 fritz daemon.info callmonitor: DEST='yyyyyyyyyyy'
Der Ruf kommt am Ziel an, obwohl das lokale Telefon das Besetztzeichen ausgibt. Eine Verbindung entsteht bei Abheben nicht.
Beim nächsten Zugriff auf die Box erfolgt ein Reboot. Ist das Problem bzw. eine Lösung bekannt? Stelle auch gerne weitere Infos zur Verfügung.
Danke!
volvic-trinker
Box und Freetz-Version stehen in meiner Signatur (FRITZ!Box Fon WLAN 7270 mit 54.04.86freetz-devel-6109)
config ist angehängt.
Wir hatten da mal ein Problem mit der libcapi. Aber das wurde im svn eigentlich behoben. Probier bitte mal "make libcapi-dirclean;make" und teste das neue Image.
Oliver
Besten Dank, das war's!
Thomas
Schön. Problem gelöst...
Oliver
rehe992
