GELOEST ! [Frage] LIMIT_WARNING_FILE ...
pt-1
5 Sep 2005
ich spiele gerade mit Asterisk 1.6.2.6 und das LIMIT_WARNING_FILE scheint nicht so zu funktionieren wie ich die Anleitung verstehe...
Lt. http://www.voip-info.org/tiki-index.php?page=Asterisk+cmd+Dial
LIMIT_WARNING_FILE - File to play as warning if 'y' is defined. If LIMIT_WARNING_FILE is not defined, then the default behaviour is to announce ("You have [XX minutes] YY seconds").
Meine Extensions.conf:
exten => 700,1,Set(LIMIT_WARNING_FILE=beep)
exten => 700,2,Set(LIMIT_PLAYAUDIO_CALLEE=yes)
exten => 700,4,Set(LIMIT_TIMEOUT_FILE=after-the-tone)
exten => 700,5,Dial(SIP/700,,L(30000:20000:5000))
exten => 700,6,Hangup
Mein Log:
= Using SIP RTP CoS mark 5
  == Using SIP VRTP CoS mark 6
    -- Executing [700@default:1] Set("SIP/702-00000000", "LIMIT_WARNING_FILE=beep") in new stack
    -- Executing [700@default:2] Set("SIP/702-00000000", "LIMIT_PLAYAUDIO_CALLEE=yes") in new stack
    -- Executing [700@default:3] Set("SIP/702-00000000", "LIMIT_CONNECT_FILE=hello-world") in new stack
    -- Executing [700@default:4] Set("SIP/702-00000000", "LIMIT_TIMEOUT_FILE=after-the-tone") in new stack
    -- Executing [700@default:5] Dial("SIP/702-00000000", "SIP/700,,L(30000:20000:5000)") in new stack
    -- Limit Data for this call:
  == Using SIP RTP CoS mark 5
    -- Called 700
    -- SIP/700-00000001 is ringing
    -- SIP/700-00000001 answered SIP/702-00000000
    -- <SIP/702-00000000> Playing 'hello-world.gsm' (language 'en')
    -- <SIP/700-00000001> Playing 'hello-world.gsm' (language 'en')
    -- Native bridging SIP/702-00000000 and SIP/700-00000001
    -- <SIP/702-00000000> Playing 'beep.gsm' (language 'en')
    -- <SIP/700-00000001> Playing 'beep.gsm' (language 'en')
    -- <SIP/702-00000000> Playing 'after-the-tone.gsm' (language 'en')
    -- <SIP/700-00000001> Playing 'after-the-tone.gsm' (language 'en')
  == Spawn extension (default, 700, 5) exited non-zero on 'SIP/702-00000000'
Der Anrufer und angerufene hoert zuerst die Hello World und dann 20 Sekunden vor Schluss alle 5 sekunden den Beep. Dann die GoodBye Ansage und dann wird aufgelegt.
Aber die Ansage ("You have [XX minutes] YY seconds") kommt nicht.
Verstehe ich da etwas falsch oder muss dies anders geloest werden ..?
PT-1
Hallo pt-1,
verstehe ich so, dass entweder das File abgespielt wird, oder wenn kein File definiert ist die Standardansage.
Rentier
mit Hand vor den Kopf schlagen ....
  == Extension Changed 702[local] new state InUse for Notify User 700
    -- Executing [700@default:1] Set("SIP/702-00000004", "LIMIT_PLAYAUDIO_CALLEE=yes") in new stack
    -- Executing [700@default:2] Set("SIP/702-00000004", "LIMIT_TIMEOUT_FILE=after-the-tone") in new stack
    -- Executing [700@default:3] Dial("SIP/702-00000004", "SIP/700,,L(30000:20000:5000)") in new stack
    -- Called 700
    -- SIP/700-00000005 is ringing
    -- SIP/700-00000005 answered SIP/702-00000004
    -- Native bridging SIP/702-00000004 and SIP/700-00000005
    -- <SIP/702-00000004> Playing 'vm-youhave.gsm' (language 'en')
    -- <SIP/702-00000004> Playing 'digits/20.gsm' (language 'en')
    -- <SIP/702-00000004> Playing 'queue-seconds.gsm' (language 'en')
    -- <SIP/700-00000005> Playing 'vm-youhave.gsm' (language 'en')
    -- <SIP/700-00000005> Playing 'digits/20.gsm' (language 'en')
    -- <SIP/700-00000005> Playing 'queue-seconds.gsm' (language 'en')
    -- <SIP/702-00000004> Playing 'digits/15.gsm' (language 'en')
    -- <SIP/700-00000005> Playing 'digits/15.gsm' (language 'en')
    -- <SIP/702-00000004> Playing 'digits/10.gsm' (language 'en')
    -- <SIP/700-00000005> Playing 'digits/10.gsm' (language 'en')
    -- <SIP/702-00000004> Playing 'after-the-tone.gsm' (language 'en')
    -- <SIP/700-00000005> Playing 'after-the-tone.gsm' (language 'en')
  == Spawn extension (default, 700, 3) exited non-zero on 'SIP/702-00000004'
  == Extension Changed 702[local] new state Idle for Notify User 700
Could not see the forest for all the trees ...
Danke !
PT-1
Callendaar
