Gigaset C450 / C460 IP Firmware update 09/2008 01072
johnwent
15 Mai 2007
Ist http://gigaset.siemens.com/chagall/1/chagall072_01.bin sinnvoll?
Download versie: 01072
Improvements:
Response time for switching the audio channel optimized
Active return loss optimized for improvement of acoustics
Mediastream with MAC address ff:ff:ff:ff:ff:ff suppressed
Allow entry of special characters in display name
Refresh timer for registering now adaptable in web config software
Connection establishment accelerated
How to update the firmware
You don't need to download files. The firmware is updated directly online by the Gigaset C450 IP. You can easily initiate the update by three steps:
Menu Settings » Base » Firmware Update
Enter base station system PIN (default setting: 0000)
Press the display key "Yes" to start the download
If your firmware is already up to date, the handset informs you. No action is needed then.
How to check for your firmware version
Via Web Configurator:
Status » Firmware version » The first 5 digits indicate the number of the firmware update.
If you are in a call (> 8 sec):
Menu » Service-Info » Scroll to list entry number 4. The first 5 digits indicate the number of the firmware update.
Almgandhi
