Gigaset C470 IP / C475 IP / S675 IP / S685 IP - Firmware update 03/2010 (version 0222
mega
IPPF-Urgestein
30 Apr 2005
The following downloads are available for product Gigaset S675 IP
Gigaset C470 IP / C475 IP / S675 IP / S685 IP - Firmware update 03/2010 (version 02223)
New features:
* Web Configurator (Settings/Telephony/Advanced Settings/Call Transfer): attended and unattended call transfer implemented.
* Web Configurator (Settings/Telephony/Audio): configurable codec list for Gigaset.net telephony implemented.
* Auto-configuration using the MAC address for retail variants implemented.
Improvements:
* Instability issue generated during G.722 Codec negotiation, when a SIP "183 Session Progress" Message is received, is fixed.
* Negotiation of speech codec after ending an external consultation call between a wideband capable (G.722 codec) and a narrowband capable phone is improved.
* Registration of more than 5 SIP accounts is possible again.
* "MWI key is permanently flashing" issue is fixed.
* MWI notification for incoming SMS via IP.*
* Improvement for Gigaset auto-configuration using TLS encryption.*/**
* PSTN: Local Area Code will be added to the dialled number if the usage of Area Codes is enabled in the appropriate dialling rule.
* Switzerland: Set [tel.search.ch] as default provider for the online directory.
* Russia: Improvements for calls with Russian Caller ID.
* provider-dependent
** device-dependent
How to update the firmware:
You don't need to download files. The firmware is updated directly online by the Gigaset C470 IP / C475 IP / S675 IP / S685 IP. You can easily initiate the update by three steps:
1. Menu » Settings » Base » Firmware Update
2. Enter base station system PIN (default setting: 0000)
3. Press the display key "Yes" to start the download If your firmware is already up to date, the handset informs you. No action is needed then.
How to check for your firmware version:
* Via Web Configurator: Status » Firmware version » The first 5 digits indicate the number of the firmware update
* If you are in a call (> 8 sec): Menu » Service-Info » Scroll to list entry number 4. The first 5 digits indicate the number of the firmware update
Danke für den Hinweis. Habe mir heute ein C475 bestellt, kann ich also direkt ein Firmwareupdate machen...
Sandra
Meinte doch das C475 IP ;) , wusste nicht, dass es das ein gleichnamiges Modell ohne IP gibt... :rolleyes:
Sandra
kerbilg
