D
Deleted member 468195
Guest
https://teamwork.gigaset.com/gigawiki/display/GPPPO/Gigaset+Fusion+-+Release+candidate+1.16.0
Release Date:
September 2023Version: Release Version
fusion-1.16.0.binWhat is new?
- NAT refresher
- rport integration
- Correction for VoIP connection transport parameter
- DECT: Transfer call via onhook
- NTP server: URL configurable via Web interface
- Playback of sound-/ringtone files uses PC-loudspeaker
Enhancements
- Blocking number optimized - blocked number is entered into list for incoming calls
- Busy message optimized - only busy tone is played
- Onboarding assistant optimized for Phone- and Web-interface
- Country, language, area codes, linetones and timezone is set
- DND and Call divert icon in Statusbar
- Call list: Options contain entry to delete list
- DECT: Call list optimized
- Doorstation: URL does not need to contain *.jpg
- Voicemail: Direct call and line selection available as options
Bugfixes
- DECT: Stabilization ("No base" in handset, call disconnect, etc.)
- External caller does not hear a dialtone
- Default system announcements corrected
- Voicemail: German date announcement corrected
- Voicemail: Missing voicemail files added (EN, ES, FR, IT)
- The line prefix 0#, 1# is shown in front of dialed number
- Telekom Germany
- Incoming calls not signalized on device
- Calls are interrupted after 30 minutes
- Default transport "automatic" - Correct negotiation with TLS transport
- Memory leak - device freezes or acts slowly - fixed
- Refresher negotiation (uas/uac) fixed
