Gigaset N530 Dialing rules
prince7273
21 Jan 2021
Couple of days ago I got the new Base station that is supposed to replace the N510. I have in my position the N300, N510, and some go and all of them have the same menu and easy functionality. On other hand the N530 is quite difficult to use and most important lacks to main functions. a) Dialing rules, b) No way to see if the voip service is registered or not similar to N300/N510
Has anyone got this device? Have you found if these two options exist? We can have 8 SIP providers and only one can be assigned for outgoing calls and all as incoming. I have multiple as outgoing and with N510/N300 I have the options to add dialing rules based on number or prefix of numbers and as worse case I can select the providers during the call. In the case of N530 there is nothing
Have you been able to have dialing plans/rules and how? Is there a way to see if the SIP accounts are registered or not?
Thanks
I did search and still I have not found anything about dialing plan or rules for the outgoing calls. If you have found any link please share it
Basically I am looking for the dialing rules where I can put some number or prefixes and N530 will use the selected SIP provider.
Hallo.
Ob registriert oder nicht ist in der BDA S.28
Die Auswahl welche Ltg genommen wird kann im Mobilteil vor dem Gespräch getroffen werden. Welche Mobilteile hast Du.
Wählregeln sehe ich auch keine.
Provider and PBX profiles. This page allows you to create a list of systems providing VoIP connections and other services for your phones. This page shows all available VoIP connections. It is only available in the Integrator user interface for the user role admin. Menu "Settings", "Provider or PBX profiles".
@prince7273 "Gigaset N530" is not an acceptable thread title. Please formulate your question or problem there. See the forum rules.
I have read the manual and the only thing that says is to assigned headset to sip account as outgoing. Only one SIP account allows me to assign. For the rest of the SIP accounts can only be incoming. I have the R700H Pro.
I have created Provider profiles but this does not resolve the dialing out rule based on the number sequence unless if there is a hiden option which I have not found yet
In der BDA vom R700H Pro auf S 17 unter Anrufen steht die Bedienung für die Auswahl der Leitung.
Which firmware version is installed on the N530?
I know about selecting the line using the R700H but it is complex procedure. My family does not know which line should be used for each call in order to go to the selection and this is the reason there are dialing rules. The N510/N300 there is a small section where we can put the numbers or sequences and we can select the line that this number should be dialed. I am looking for the same functionality in N530
The latest. 2.66. I did a firmare update 2 days ago after I set it up
Also I remember that In N510 we could save the numbers with #2 at the end which indicates this call will be routed using the IP2 or #9 which means the landline. I do not see this functionality either
I did some research and I found out that I can not select a dialing out line neither I have dialing plans on the menu. Or gigaset forgot to enable this on the menu, or excepts from us to do it in xml (there is no available information for creating an xml) or just simply the N530 with the current firmware does not support dialing out rules. It does not make sense to have 8 SIP accounts to configure and not to be able to have dialing out rules.
Ptioklyura
