Gigaset S450 IP Firmware update 11/2008
georg.friedrich
3 Aug 2006
Servus,
fuer alle die an den Infos ueber die neue Firmware interessiert sind:
LG
Georg
Download version: 02139
New Features:
* Online directory for Switzerland provided by [tel.search.ch]
* HTTP Proxy support. For example online directory can be used in company environments via an HTTP proxy server.
Improvements:
* Fast media switching improved (due to partial loss of provider cost rate announcements, e.g. at Sipgate)
* Indication of VoIP waiting calls improved
* Firmware update procedure starts before VoIP connection assistant.
* Store the complete caller information in the "Missed Calls" list, if it is retrieved from online directory
* Optimised presentation of search results in Yellow Pages (on C47H, S67H, S68H handsets)
* Gigaset.net assistant starts if the user opens Gigaset.net directory for the first time and there is no corresponding Gigaset.net nickname. It does no longer start after the VoIP connection assistant.
* The phone deregisters from registrar server, once the SIP account is disabled.
* Wideband support for A58H/C38H handsets improved
* SMS wizard disabled (subscription to SMS service is no longer necessary)
* Handling of IP dialling improved
* Automatic user login by accessing the Gigaset.net configuration page via Web configurator
* Handling of multiple network mailboxes improved
* Translation errors fixed
* Support of new daylight saving time rule for New Zealand
* Sipgate echo test supported again (handling of RTP sequence numbers)
ECO-Modus
Mir ist grad bei Sonderfunktionen der "ECO"-Modus aufgefallen. Weiss jemand, was sich dahinter verbirgt?
Hallo ccie,
der ECO-Modus hat jetzt aber nichts mit dem Firmware-Update zu tun.
Was sich dahinter verbirgt findet man in der Bedienungsanleitung, auf den Gigaset-Seiten im Netz und hier im Forum mit der Forumssuche. Mit letzterer findet man z. B. folgende Beiträge: http://www.ip-phone-forum.de/showpost.php?p=1148610&postcount=22 (ff.), http://www.ip-phone-forum.de/showpost.php?p=1119021&postcount=1 (ff.).
Kurz und knapp: Eco-Modus: Reduzierung der Sendeleistung der Basis um 80% (damit verbunden eine reduzierte Reichweite)
Viele Grüße,
Jirka
... und Reduzierung der (kontrovers diskutierten) Funkabstrahlung und des Stromverbrauches.
Almgandhi
