Habe mit sporadisch auftretendem Fehler ein Problem
ploieel
Aktives Mitglied
13 Mrz 2005
Hallo Expertenteam;
wenns mal funktioniert, sieht das Ganze so aus:
fli4l*CLI>
  == Primary D-Channel on span 1 up for TEI 64
  == Primary D-Channel on span 1 up for TEI 65
    -- Accepting overlap voice call from '111' to '<unspecified>' on channel 0/2, span 1
    -- Starting simple switch on 'Zap/2-1'
    -- Accepting overlap voice call from '111' to '<unspecified>' on channel 0/1, span 1
    -- Starting simple switch on 'Zap/1-1'
May  5 17:04:36 WARNING[17963]: chan_zap.c:8777 zt_pri_error: 1 received SETUP message for call that is not a new call (retransmission).
May  5 17:04:36 WARNING[17963]: chan_zap.c:10258 pri_dchannel: Hangup requested on unconfigured channel 255/255 span 1
    -- Channel 0/2, span 1 got hangup, cause 81
    -- Channel 0/2, span 1 received AOC-E charging 3223857 units
    -- Hungup 'Zap/2-1'
    -- Going to extension s|1 because of empty extension received on overlap call
May  5 17:04:44 WARNING[25059]: chan_zap.c:8777 zt_pri_error: 1 Can't destroy call -1209584056!
May  5 17:04:44 ERROR[25059]: chan_zap.c:2930 zt_hangup: What is wrong with you? You cannot use cause 1 number when in state 1!
    -- Hungup 'Zap/1-1'
    -- Executing Dial("Zap/2-1", "SIP/2232@2232|60|Ttr") in new stack
    -- Called 2232@2232
    -- SIP/2232-081ccc18 is ringing
    -- Channel 0/2, span 1 got hangup request
  == Spawn extension (default, 2232, 1) exited non-zero on 'Zap/2-1'
    -- Hungup 'Zap/2-1'
  == Primary D-Channel on span 1 down for TEI 64
fli4l*CLI>
Kurz danach das Ganze nochmals versucht, meldet sich der Asterisk überhaupt nicht.
Etwa 5 Minuten warten, dann kommt das Gleiche vor wie oben beschrieben.
Ist mir zu noch zu helfen, und wenn ja, wie?
Günter
itseb
