Help: FRITZ!Box Fon WLAN 7270 from Austria = English International Annex A??
bjluv
29 Dez 2005
I am visiting vienna, Austria soon and I have been made to understand that in Austria, Annex A is used. I have been checking various shops in Vienna that sells FRITZ!Box Fon WLAN 7270 but some of them have something like FRITZ!Box Fon WLAN 7270 Annex A/CH for Österreich.
On another site, I think shoxx.com, listed Finland and Austria as using same Annex A.
[Edit Novize: Please use the attach-function of the board - external image deleted]
http://i525.photobucket.com/albums/cc336/daikkunen/imagemarkphp.jpg
Does this mean that if I buy the FRITZ!Box Fon WLAN 7270 Annex A from any shop in Austria, I can use it without any problems here when I get back to Finland? Is it also in English and if not, can the language be easily converted to English? :p
Thanks for your help! :groesste:
The A/CH version can be changed from annex A to B by menu, and vice versa. So you can use it later on in all areas.
I need to basically have Annex A because that is what we use in Finland. Do you have any idea if the configuration page is in English or German?
Hello bjluv
According the last thread of the link below the german version can allready be switched to four different languages.
I think in that case the international version should at least be able to be switched between the same amount of languages or even more.
http : // w w w .redl-web.at/2008/01/21/fritzbox-7270-oesterreich-version/
As you may allready have realised the german version can also be changed via web interface between Annex A and B.
However if you never need Annex B it migth be more comfortable to buy the Annex A box, since that modem should be more powerful ih analoge DSL networks.
If you would often use the latest Labor firmwares it would be better to buy the Annex B box since for the Annex A box the release of new firmwares will be more rare.
It think you could be able to find Annex B boxes for half of the price what you would have to pay for Annex A boxes.
Regards
Urs
There is too much information here :)
I am going to be using the Box here in Finland and we use Annex A here. The A/CH version have both Annex A and B so is this better option than the International Annex A version?
It is good to know all the version have the option to change to English but the most important thing is that does the A/CH version works the same way???
The German version, Annex B is cheaper yes but how easily is it to convert to Annex A so I can use it here in Finland??
Posting 2:
Can anyone here please reply to my concerns above?? thnx
If I buy Annex A - A/CH version, does it work like International version?
If I buy Annex B - German version, can I convert easily to international Annex A version with English & also step and step information please? :)
Thanks 1A1 for your help...you are so marvellous...
mmoo2026
