Help Me! Please ...
antep0510
22 Mai 2007
Type: Fritz!Box Fon Wlan
(Power Led, internet Led, Festnetz Led) light
at the same time Flashing, I think the defective device :confused:
What can I do ? :(
Thanks ...
Did you try to reset the box by phone by dialing #991*15901590*?
Did you try a recover descripted as here (sorry this page is german only)?
really no tone?
Did you try it anyway? What does the box do if you try it anyway?
Feuer-Fritz
yes I tried ..
Fon1 and Fon2 no dial tone ..
then the only idea that I have is a recover
What is the FW-verison on the box? Do you know that?
Feuer-Fritz
ftp 192.168.178.1
adam2 und adam2
login Okey
quote SETENV annex A
quote SETENV HWRevision 66
quote SETENV ProductID Fritz!Box_FON_WLAN
quote SETENV firmware_version avme
quote SETENV firmware_info 08.04.49
fritz.box_fon_wlan.annexa.en.04.49.recover-image OKEY No Problem
FRITZ!Box Fon WLAN Annex A, Firmware version 08.04.49
aber die gleiche Situation. Power-internet-festnetz Licht signal
das sieht dann doch nach Hardeware-defekt aus....
nimm mal die Box für eine Weile vom Strom und allen Kabeln....
geht das auch auf deutsch für Dich?
Feuer-Fritz
Danke für die Relevanz
Did you understand what I wanted to say?
If not:
It seems to be a hardware damage.
Please pull off any cable from the box and wait a while (about half an hour) and then try again, maybe it will work again. If not I think your box is damaged.....
Elemir
