Help me restore FritzBox 7050 to default
bjluv
29 Dez 2005
Hello,
A friend was away on a business trip and the wife switch the internet provider. Now FritzBox 7050 will not connect to the new provider because the VCI & VPI
does not match. I tried to get to fritz.box but it was unsuccessful...:confused:
Can someone here please help so that I can also help return the box to the factory default state?
Thnx.
Connect an analog telephone to one of the telephony ports (Fon 1 or Fon 2) and dial
#991*15901590*
This will reset the box to factory settings.
thanks but now the box went bad when i plugged it. something exploded from inside and now it wont come on again :(
Maybe this is a bad box now :(
