Help with 7270/fritz!fax in English please
gcf
11 Nov 2007
I used to send faxes with a 7140 and fritz!fax over an Annex A (PSTN) landline with no problems.
I recently upgraded to a new pc (still xp OS) and a 7270.
I try to follow this tutorial
http://www.ip-phone-forum.de/showthread.php?t=197285
but any faxes I send get "ABGEBROCHEN"
How should I configure the ISDN options (for a PSTN landline)
Should I set the "ISDN controller" to
- ISDN-Controller [what value]?
or AmtSanschluss ISDN
or AmtSanschluss Analog ?
In Erweiterte Einstellungen what are the right settings?
Thanks in advance
for Annex A you need "Amtsanschluss Analog" or fill in 4 in the Controller-Inputfield.
  • deactivate the Button "Telefax-G3-Dienst des ISDN-Controllers nutzen"
and at the extended ISDN settings activate the Checkboxes
  • Analoges Fax
  • Faxempfang auch bei Dienstekennung "Sprache"
Vielen Dank, alles ist gut :)
JSt Aero
