Help with patton SN4522/JS/EUI and softphone
vladimir.aleksi
17 Mrz 2007
Dear All,
I have problem with Patton 4522 which is connected to voip platform yate (as like asterisk) with sip protocol. And I am trying to dial from X-Lite softphone which is connected to yate with sip protocol. On X-Lite is iLBC codec and on patton is g729 codec. When I am dialing from my softphone to patton evrything working fine perfekt. But when I am dialing from Patton box to my softphone my softphone ringing and as soon as I pick up phone on X-Lite I am getting disconnection. I check in yate no error, but in Patton debug I found:
Set call-leg property: Cause -> Service or option not implemented, unspecified (415)
Down is my configuration from Patton.
Can somebody help me and tell me what is exactly problem in Patton configuration?
Edit Guard-X: Code Tags inserted!
context cs switch
  routing-table called-e164 ROUTE_MAIN
    route 100160 dest-table ROUTE_LOKAL
    route 100170 dest-table ROUTE_LOKAL
    route 100... dest-interface sip_int CLI_LOKAL
  routing-table called-e164 ROUTE_LOKAL
    route 100160 dest-interface FXS-1 OUT_LOKAL
    route 100170 dest-interface FXS-0 OUT_LOKAL
  mapping-table calling-e164 to calling-e164 CLI_LOKAL
  mapping-table itc to itc speech
    map default to speech
    map unrestricted-digital to unrestricted-digital
  interface sip sip_int
    bind gateway PnInlpSipGw
    service logicunited
    route call dest-table ROUTE_MAIN
    early-connect
    early-disconnect
  interface fxs FXS-1
    subscriber-number 100160
  interface fxs FXS-0
    subscriber-number 100170
  service hunt-group HUNT
    cyclic
    drop-cause normal-unspecified
    drop-cause no-circuit-channel-available
    drop-cause network-out-of-order
    drop-cause temporary-failure
    drop-cause switching-equipment-congestion
    drop-cause access-info-discarded
    drop-cause circuit-channel-not-available
    drop-cause resources-unavailable
    route call 1 dest-interface FXS-1
context cs switch
  no shutdown
gateway sip PnInlpSipGw
  no transport tcp
  bind interface eth0 router
  service logicunited
    domain 172.16.13.10
    realm 172.16.13.10
    default-server 172.16.13.10 loose-router
    registrar 172.16.13.10
    user PnInlpSipGw display-name PnInlpSipGw password GHQfLhDdffgIghdRPpRZN3TQA== encrypted
  no shutdown
port ethernet 0 0
  medium auto
  encapsulation pppoe
port ethernet 0 0
  no shutdown
port ethernet 0 1
  medium auto
  encapsulation ip
  bind interface eth1 router
  no shutdown
port fxs 0 0
  battery-reversal
  encapsulation cc-fxs
  bind interface FXS-0 switch
  no shutdown
port fxs 0 1
  battery-reversal
  bind interface FXS-1 switch
  no shutdown
I hope that somebody will help me
Thank you very much.
Siouiyltua
