hfc harte im NTmodus macht probleme
anfänger
21 Okt 2004
ich hab ein meinem server eine fritzcard und eine hfc kare im nt modus an die ich ein isdntelefon anschliessen will. aber wenn ich den hörer abnehme spuckt asterisk folgendes aus:
Asterisk Ready.
*CLI> bri intense debug span 1
Enabled EXTENSIVE debugging on span 1
*CLI> Nov 29 13:26:11 NOTICE[-185234512]: chan_sip.c:7889 sip_poke_noanswer: Peer 'sipgate' is now UNREACHABLE!
Received a Q.921 message from strange/unassigned TEI 127.
< [ fc ff 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 ]
< Unnumbered frame:
< SAPI: 63  C/R: 0 EA: 0
<  TEI: 127        EA: 1
<   M3: 3   P/F: 1 M2: 1 11: 3  [ ??? ]
< 19 bytes of data
Nov 29 13:26:15 WARNING[-168383568]: chan_zap.c:7275 zt_pri_error: PRI: !! Weird frame received (m3=3, m2 = 1)
< [ fe ff 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 77 ]
< Unnumbered frame:
< SAPI: 63  C/R: 1 EA: 0
<  TEI: 127        EA: 1
< 22 bytes of data
Nov 29 13:26:16 WARNING[-168383568]: chan_zap.c:7275 zt_pri_error: PRI: !! Weird frame received (m3=3, m2 = 1)
< [ fe ff bb ]
< Unnumbered frame:
<  TEI: 127        EA: 1
<   M3: 5   P/F: 1 M2: 2 11: 3  [ ??? ]
< 0 bytes of data
Nov 29 13:26:17 WARNING[-168383568]: chan_zap.c:7275 zt_pri_error: PRI: !! XID frames not supported
< [ 7e ]
< Unnumbered frame:
< SAPI: 31  C/R: 1 EA: 0
<  TEI: 127        EA: 1
< -2 bytes of data
Nov 29 13:26:18 WARNING[-168383568]: chan_zap.c:7275 zt_pri_error: PRI: !! Received short unnumbered frame
< [ 04 ff d9 99 96 dd dc d9 99 99 ]
< Supervisory frame:
< SAPI: 01  C/R: 0 EA: 0
<  TEI: 127        EA: 1
< Zero: 13     S: 2 01: 1  [ REJ (reject) ]
< N(R): 076 P/F: 1
< 6 bytes of data
Nov 29 13:26:19 WARNING[-168383568]: chan_zap.c:7275 zt_pri_error: PRI: !! Got S-frame while link down
< [ 66 ff 19 ]
< SAPI: 25  C/R: 1 EA: 0
<  TEI: 127        EA: 1
< Zero: 1     S: 2 01: 1  [ REJ (reject) ]
< N(R): 008 P/F: 0
< -1 bytes of data
meine zaptel.conf:
loadzone=nl
defaultzone=nl
span=1,1,3,ccs,ami
bchan=1-2
dchan=3
zapata.conf:
[channels]
switchtype=euroisdn
signalling=bri_net_ptmp
pridialplan=local
echocancel=yes
immediate=no
overlapdial=yes
group=1
context=default
channel=>1-2
weiss einer rat?
danke anfänger
An der HFC hast Du doch sicherlich einen NT dran, oder hat das Telefon eine eigene Stromversorgung?
Raffi
Was genau ist es denn für ein Telefon? Nicht dass es in wirklichkeit ein System- und kein echtes ISDN-Telefon ist...?
Ich habe eine NTBA Dann kommt mein t-easy isdn telefon (die ntba und das telefon hingen auch schon zusammen an meinem alten isdnanschluss) beide haben im moment eine strohmversorgung. ich hatte zum testen auch eine isdn auf analog TK anlage drangehängt mit dem gleichen ergebnis.
Die Verschaltung habe ich wie folgt vorgenommen:
NT karte zur NTBA
A1 -> pin 3
B1 -> pin 6
A2 -> pin 4
B2 -> pin 5
Ergibt zwischen den kabeln
4 zu 3
5 zu 6
3 zu 4
6 zu 5
anfänger
Belgarath4
