High CPU load when using all bandwidth leads to reboot
Michael999
24 Dez 2008
Hello everyone,
First of all I'd like to say freetz and the freetz community is great! Second, I've been using freetz for over a year now and I'd like to say this forum has been extremely helpful in answering question and solving problems.
My written German is very poor so I hope you don't mind I ask a question in English.
I have a FRITZ!Box Fon WLAN 7170 and recently converted the box to English and to Firmware version 29.04.82, using the latest freetz trunk with usb-root. Now for the problem. Whenever I use my full bandwidth when for example downloading a linux distribution, I have a cpu load of around 86 % and after a few minutes of downloading it leads to a reboot.
"top" shows the processes using the most CPU time when downloading are:
1803 1 root RWN 0 0% 38% [kdsld_token]
701 1 root S 5516 18% 25% telefon a127.0.0.1
548 5 root SW< 0 0% 21% [capi_oslib]
when not downloading cpu usage is ~1-2%.
I'm not sure what kdsld_token exactly does and maybe there is a good reason why its cpu load is so high, but i don't get why the telephone and capi_oslib processes are as high as they are when I'm downloading.
I reckon when I get those cpu loads down the box won't go into a reboot anymore.
Can anyone help me understand/solve this problem?
Hardware: FRITZ!Box 7170 Annex B
Firmware: 29.04.82freetz-devel-5088 (replaced kernel, ipv6)
Patches: signed, freetzmount, automount ext2, raise usb count, aura usb, CAPIoverTCP, dtrace, help, mediaserv, minid, smbd, support, tr069+fwupdate, , UPnP, usermand, redirect
Packages: busybox-1.16.2, avm-firewall, cpmaccfg, rrdstats, spindown, syslogd, virtual ip, vnstat, callmonitor, dnsmasq, dropbear (+openssh for sftp), nano, netcat, openntpd, php, screen, tcpdump, transmission, vsftpd, lighttpd, rsync, usb root, wol
You could use trickle (a bandwidth shaper) to control / regulate your bandwidth / download.
click, click, click.
Limiting the bandwidth does work. However, when I was using the German firmware 04.80 as recently as last week, I had no problem using all of my bandwidth. I could go back to the German firmware, but there should be a reason why this is happening with the latest English and not the latest German firmware.
Because I also converted freetz to English I have recompiled freetz with the same patches/package selections (the ones i wanted were all available in English) using a "make dirclean" and "make config-clean-deps", but I can't figure out what's wrong. Therefore i looked at the cpu load of the FRITZ!Box and noticed the high cpu usage by the telephone and capi_oslib processes. These weren't that high when using the German firmware.
So I'm thinking there must either be something wrong with the English 04.82 firmware or I did something wrong compiling freetz when converting to English.
Did you use the same .config for the german firmware? "replace kernel"? ipv6? Did you try the English firmware without "replace kernel"?
Regards
Oliver
Thanks for your suggestions.
I had some .config issues after svn updates in the past, so when I decided to convert it to english I downloaded a fresh freetz trunk and re-selected all the packages I used with the german firmware by hand.
After a "make dirclean" and "make config-clean-deps" i followed your suggestion and compiled it without "replace kernel". I check the cpu usage ,when downloading, in the fritz!box and it still showed a very high cpu load by these processes:
49% [kdsld_token]
22% telefon a127.0.0.1
12% [capi_oslib]
After using all of my bandwidth for about 3 minutes the box rebooted.
I'm at a loss here as to what's going on, what the problem is. Do you maybe have any other suggestions?
Can you please try this firmware without IPv6 support?
Regards
Oliver
Ok, so I tried several combinations. I first removed all non-relevant packages.
1. Tried with the english firmware + replace kernel + ipv6 support -> crash when using full bandwidth
2. Tried with the english firmware + replace kernel -> crash when using full bandwidth
3. Tried with the english firmware + nothing -> crash when using full bandwidth
4. Tried with the german firmware + replace kernel + ipv6 support -> works fine
The only conclusions I can draw is that there's either something different wrong/different with the english firmware or some part of freetz/some of the packages aren't working well with the english firmware.
Why do you suppose that is?
Did you have a look into the syslog/dmesg just before the reboot?
Regards
Oliver
Is there any way the see the syslog/dmesg of the box from before the reboot, after a reboot? This, because the reboot doesn't always happen at the same time. When I randomly check a few times during full bandwidth usage there's nothing out of the ordinary in the logs.
I think I'll just stick with the german firmware for now, it's no problem, I can understand what it all says. It would be nice to know though what the problem was, but right now I'm not sure.
I also checked the cpu load when using the german firmware (and using all bandwidth) and it's significantly lower:
16% telefon a127.0.0.1
10% [capi_oslib]
3% top
2% [kdsld_token]
The cpu usage of the telefon, capi_oslib and kdsld_token processes are all three much lower, but kdsld_token is the one that differs the most. With the english firmware it's been between 35%-50%, now it doesn't even come above 3%.
stego88
