How to check debug.cfg
hrust_ray
11 Jan 2007
Hallo. Sorry for english.
How can I check what is currently inside debug.cfg?
I tryed to insert some commands there, but after restarting the dont execute.
I modifyed debug.cfg by this command:
cat /var/media/ftp/1.txt > /var/flash/debug.cfg
file 1.txt was placed on root ftp directory
you can check it with:
nvi /var/flash/debug.cfg
Thx!
There are correct lines inside
ifconfig eth0:0 192.168.178.2 netmask 255.255.255.0 up
cd /var/media/ftp/MassStorageDevice-Partition-0-1/wt
./install.sh
But this lines seems are not executing on FB reboot. Maybe I should active something to force FB use default.cfg?
You should add a "sleep"-command. You can't change directory to your USB-Device if this is not mounted at that moment.
Alles klar.
This mean the first line should be
sleep 15
for example? Is it in secs?
hrust_ray schrieb:
Yes. Just try out which time is needed to mount the USB-device. I'd try sleep 45.
Gruß,
Wichard
Ok.
One more thing. Is it possible to log messages from debug.cfg execution to file?
I know in dos it is possible by command_name > log.txt
Or it is dangerous to overflow flash memory capacity?
It depends on the size of the log-file. Most log-files should fit onto a 512MB USB-STick ;)
However, I had some problems logging onto the USB-Stick in the past: With a 7170 it worked fine, but with a 3070 the USB device froze after some days. The size of the Logfile was not the problem.:confused:
"flash-memory" - I'm talking about FB flash memory, not usb-stick
I don't think that it is a good idea to log directly to the Box-flash, because the flash-memory is very small (some 10KB's) and you can only write through virtual files like debug.cfg (debug.cfg is not a real file!) into it.
It's possible to create a new file in /var/flash, but after reboot the file doesn't exist anymore. The only way would be using the debug.cfg as logfile.
Ok.
That what I need - create temporary log files, that contains log from last booting sequence from debug.cfg.
After rebooting log files are deleted and created againg. So I have possibility to check logs from last booting.
It seems to be realistic.
In this case it would be better to create the Logfile on the RAM-Disc in /var/tmp
Yes, It's better. The last problem - how?
command_name > /var/tmp/log.txt
What happenes in this case?
command_name_1 > /var/tmp/log.txt
command_name_2 > /var/tmp/log.txt
command_name_3 > /var/tmp/log.txt
command_name_4 > /var/tmp/log.txt
/var/tmp/log.txt will contain finally logs from all 4 commands, or only from last command?
That version contains only the last one. You should use
command_name_2 >> /var/tmp/log.txt
command_name_3 >> /var/tmp/log.txt
command_name_4 >> /var/tmp/log.txt
snowdrift
