How to conf. DHCP Client (bind MAC addr.& IP)
_ps7ch0_
24 Feb 2008
Hello *,
I'm trying to use the dhcp server built-in in the box, but I have an issue:
I'm trying to bind IP address vs mac address.
I have tried to use multid.lease but this one doesn't seem to work.
this is the sequence use:
multid -s
nvi /var/flasch/multid.leases (change only the ip)
multid
But unsuccessful...
Someone should help me.
Thanks
either use the latest lab firmware where you can use the GUI to assign static IPs.
Or you can use dnsmasq and the freetz GUI to configure it.
Best regards,
Whoopie
Hi Whoopie,
Thanks... I have just build a new version with dnsmasq. I'm trying to use this.
Thanks a lot.
figo12
