How to set the clock?
vasila
7 Mai 2008
Hello,
My FB with freetz Devel needs to set the clock !!!
I have the timezone manualy set:
timezone_manual {
        enabled = yes;
        offset = 0;
        dst_enabled = no;
        TZ_string = "WET-0WEST-1,M3.5.0/01:00:00,M10.5.0/02:00:00";
        name = "";
but the hour/minutes is not correct !!!
How can i set the hour/minute ??
Best Regards
Thank you
Hi vasila,
I think, there are at least 2 mistakes in your definitions:
dst_enabled = no;
This parameter should be set to yes to enable DaylightSavingTime.
What timezone do you want to select? WET or WEST :noidea:
Assuming you are living in Ireland, please try:
dst_enabled = yes;
        TZ_string = "WET-0,M3.5.0/01:00:00,M10.5.0/02:00:00";
Joe
btw: Please set up your own signature. ;)
Factory22
