How, where to disable the firewall into 7050?
zooster
4 Jan 2006
I don't find where to disable the firewall :(
Why do you want to do this? What do you want to do after you disabled the firewall?
Ah, ok.
As far as I know there are no good ways to disable the firewall and keep the router functions of an FBF up at the same time. FBFs run a Linux, and there you do the NAT stuff in your firewall rules.
Do you think that there is a way to enhance the high ping? Do you have an idea why it's higher? And what and where is this option that I found online somewhere, dsl filter??
I think there is (unfortunately for you) no way to enhance the ping, sorry. I suppose pinging via the FBF is slower (higher time count) because the FBF is just doing its routing job slower than your Alcatel router.
I can translate the menu items you have to click...
It should be Internet->DSL-Einstellungen->DSL-Filter für DSL-Modem aktivieren
This is without guarantee as my FBF is just the one without a DSL-modem, so I can't tell for sure.
Thank you.
