HOWTO configure Hiawatha web server on my fritz box 7170?
Hello M66B, Hello sf3978,
What do I have to do in order to get the following result on my freetz box:
[root@host jeffy]# /usr/local/sbin/hiawatha -v
Hiawatha v7.4.1, cache, IPv6, Monitor, SSL, URL toolkit, XSLT
Copyright (C) by Hugo Leisink <[email protected]>
At the moment I get this on my freetz box:
root@fritz:/var/mod/root# /usr/bin/hiawatha -v
Hiawatha v7.4.1
I unsuccessfully tried to edit file
freetz-trunk/make/hiawatha/hiawatha.mk
from
$(PKG)_CONFIGURE_OPTIONS += --disable-cache
$(PKG)_CONFIGURE_OPTIONS += --disable-largefile
$(PKG)_CONFIGURE_OPTIONS += --disable-ipv6
$(PKG)_CONFIGURE_OPTIONS += --disable-ssl
$(PKG)_CONFIGURE_OPTIONS += --disable-toolkit
$(PKG)_CONFIGURE_OPTIONS += --disable-xslt
$(PKG)_CONFIGURE_OPTIONS += --disable-monitor
to
#$(PKG)_CONFIGURE_OPTIONS += --disable-cache
#$(PKG)_CONFIGURE_OPTIONS += --disable-ipv6
#$(PKG)_CONFIGURE_OPTIONS += --disable-ssl
#$(PKG)_CONFIGURE_OPTIONS += --disable-toolkit
#$(PKG)_CONFIGURE_OPTIONS += --disable-xslt
#$(PKG)_CONFIGURE_OPTIONS += --disable-monitor
because you need to remove --disable-toolkit for example during mipsel-linux-uclibc compilation in order to have URL toolkit support.
The binary file
freetz-trunk/packages/target-mipsel_uClibc-0.9.29/hiawatha-7.4.1/root/usr/bin/hiawatha
remains always the same size that might indicate an increased set of functions (my required URL toolkit support).
According to my first thread entry I have not yet updated my current freetz configuration with the new patch.
Do you have any ideas how to compile hiawatha for my freetz box with URL toolkit support?
Thank you for your help!!
$(PKG)_DEPENDS_ON := openssl zlib [COLOR=red]xsltproc[/COLOR]
$(PKG)_CONFIGURE_OPTIONS += --enable-cache
$(PKG)_CONFIGURE_OPTIONS += --enable-ipv6
$(PKG)_CONFIGURE_OPTIONS += --enable-ssl
$(PKG)_CONFIGURE_OPTIONS += --enable-toolkit
[COLOR=red]$(PKG)_CONFIGURE_OPTIONS += --enable-xslt[/COLOR]
$(PKG)_CONFIGURE_OPTIONS += --enable-monitor
root@fritz:/var/media/ftp/uStor01/archiv# ldd ./hiawatha
        libcrypt.so.0 => /lib/libcrypt.so.0 (0x2aabe000)
        libssl.so.0.9.8 => /usr/lib/freetz/libssl.so.0.9.8 (0x2aae2000)
        libcrypto.so.0.9.8 => /usr/lib/freetz/libcrypto.so.0.9.8 (0x2ab2e000)
        libz.so.1 => /usr/lib/freetz/libz.so.1 (0x2ac3f000)
        libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x2ac62000)
        libpthread.so.0 => /lib/libpthread.so.0 (0x2ac80000)
        libc.so.0 => /lib/libc.so.0 (0x2aca3000)
        libdl.so.0 => /lib/libdl.so.0 (0x2ad1e000)
        ld-uClibc.so.0 => /lib/ld-uClibc.so.0 (0x2aaa8000)
root@fritz:/var/media/ftp/uStor01/archiv# ./hiawatha -v
Hiawatha v7.5, [COLOR=red]cache, chroot, CommandChannel, IPv6, Monitor, SSL, URL toolkit[/COLOR]
At the moment xsltproc doesn't compile properly on Freetz:
./libxslt/.libs/libxslt.so: undefined reference to `htmlNewDocNoDtD'
../libxslt/.libs/libxslt.so: undefined reference to `htmlDocContentDumpFormatOutput'
../libxslt/.libs/libxslt.so: undefined reference to `htmlNewDoc'
../libxslt/.libs/libxslt.so: undefined reference to `htmlDocContentDumpOutput'
../libxslt/.libs/libxslt.so: undefined reference to `htmlSetMetaEncoding'
collect2: ld returned 1 exit status
make[3]: *** [testThreads] Fehler 1
So we have to wait till ...
EDIT:
Please try this patch for hiawatha-7.6.
If you select xsltproc in menuconfig then it should work? A "make xsltproc" without this selection doesn't build libxml2 with html support.
Oliver
Looki_Luzi
