[Problem] I selected the busybox applet "wall", but it doesn't do anything...
frater
23 Nov 2008
I created an init-script which wants to reboot the fritzbox.
Before it does, I want to use this command to broadcast a message to those logged in with SSH that the fritzbox is going to reboot.
The problem is that it doesn't do anything.....
SSH must be compiled with utmp/utmpx support (s. wall implementation)
Depending on what package you use for SSH you have either to select the corresponding option in menuconfig (dropbear) or enable it manually in openssh.mk (the latter one is untested).
Thanks
I will test this.
Yes, it works now.
Thanks er13
holh-66
