iaxtel.com macht schlapp ?
mac_7
25 Jan 2005
kann es sein das iaxtel derzeit mit den login/refresh requests
für das iax2 überlastet ist?
es dauert immer länger bis zum State: Registered
meist steht da nur State: Request Sent
alle anderen wie fdw, sipgate&co sind immer sofort da
Bei mir ebenfalls!
Ich hab mal eine Mail geschickt:
dear iaxtel,
have you recognized that there are problems with login/refresh attempts
most (not all) of the time the iax2 state is "Request Sent"
all other are Registered
connection and bandwidth are OK
you have a significant packet lost problem
[root@dell root]# ping -c9 69.73.19.178
PING 69.73.19.178 (69.73.19.178) 56(84) bytes of data.
64 bytes from 69.73.19.178: icmp_seq=1 ttl=50 time=108 ms
64 bytes from 69.73.19.178: icmp_seq=2 ttl=50 time=109 ms
64 bytes from 69.73.19.178: icmp_seq=4 ttl=50 time=106 ms
64 bytes from 69.73.19.178: icmp_seq=6 ttl=50 time=108 ms
64 bytes from 69.73.19.178: icmp_seq=7 ttl=50 time=109 ms
64 bytes from 69.73.19.178: icmp_seq=8 ttl=50 time=108 ms
64 bytes from 69.73.19.178: icmp_seq=9 ttl=50 time=107 ms
--- 69.73.19.178 ping statistics ---
9 packets transmitted, 7 received, 22% packet loss, time 8000ms
rtt min/avg/max/mdev = 106.782/108.322/109.568/0.954 ms
best regards
and thx for the free service ;-)
Nach einer Woche kam die Antwort:
Hello sir
Iaxtel is a wonderful free service, and it has been under
reimplementation for several months to deal with the recent massive
increase in users, over 6000 at my last count. Needless to say we have
not been able to keep up please be patient as we improve this service.
Matt
Slasher625
