IeEmbed.exe file missing - problem with jfritz
ilex_ilex
16 Nov 2006
Hi to All,
I use Jfritz for at least 2 years with positive results till last update to version 7.3.10.
Now with every start of Jfritz I get an error massage:
File lib/windows/x86/IeEmbed.exe could not be found
After I press OK jfritz continues with star with positive result.
I have uninstalled jfritz & installed it over again - still have the same problem.
I have additionally checked windows XP registry - have not found any key or value with that name.
Does anyone know how to solve this problem ?
Greetings
Mikolaj
Hello Mikola,
i think this looks like a java problem. Please check if the correct java version is installed. JFritz needs 1.5 or higher.
Greetings juergenausbw
It did not work :(
I have reinstalled java but problem remainded :/
any other hints ?
Mikolaj
Hello Mikolaj,
try this to solve your problem:
- First make sure JFritz is not started.
- Then do a backup of your JFritz-Installation-Directory
- Do also a backup of C:\Users\<Username>\AppData\Local\VirtualStore\Program Files (x86)\JFritz
- Copy all files from C:\Users\<Username>\AppData\Local\VirtualStore\Program Files (x86)\JFritz to your JFritz-Installation-Directory and overwrite all files.
- Delete the Directory C:\...\VirtualStore\...\JFritz
Best regards,
Robert
Not much luck.
Maybe that part of error log can be helpful to find out what is my problem:
(07.10.09 16:46:14): INFO: Set debug level to LS_INFO
(07.10.09 16:46:14): JFritz v0.7.3.10 (c) 2005-2009 by all members of the JFritz-Team
(07.10.09 16:46:14): INFO: Installing shutdown hook...
(07.10.09 16:46:14): ERROR: java.lang.IllegalArgumentException: Unknown signal: HUP
(07.10.09 16:46:14): ERROR: java.lang.IllegalArgumentException: Unknown signal: KILL
(07.10.09 16:46:14): ERROR: java.lang.IllegalArgumentException: Signal already used by VM: SIGBREAK
(07.10.09 16:46:14): INFO: Shutdown hook installed!
hBrumann
