Incoming Call problem with patton SN4522/JS/EUI
bagigione
29 Okt 2007
good evening to all, my VoIP network architecture is: patton-->gatekeeper-->media gateway (as5400) (connect gatekeeper to pstn).. the smartnode registers correctly to gatekeeper, all kind of outgoing calls goes right, but when I try to call from pstn (like mobile phone, home phone..) I can t see incoming call neither on gatekeeper nor on patton.. but on media gateway I can see this error message using command 'debug isdn q931': "No route to destination"
debugging an outgoing calls on smartnode I ve seen this line, at the end of the call:
16:28:30 HRAS > Stack: Received Disengage Confirm
16:28:30 H323 > [EP TO-GK-0001] < Stack: State: IDLE
16:28:30 H323 > [EP TO-GK-0001] < SM : Event TERMINAL RELEASE (State RELEASED)
16:28:30 H323 > [EP TO-GK-0001] > Stack: Closing call 0x00c3a598...
16:28:30 H323 > [PR TO-GK] Removed endpoint TO-GK-0001
16:28:30 H323 > [PR TO-GK] Destroyed endpoint TO-GK-0001
16:28:30 H323 > [EP TO-GK-0001] Destroy mode
16:28:30 H323 > [EP TO-GK-0001] Destroyed
16:28:46 HRAS > Stack: Received Registration Confirm
16:28:46 HRAS > Stack: Registered to gatekeeper: 10.174.176.3/1719
the interesting lines for me were:destroy mode and destroyed.... is a normal call clearing process or when it destroyes the endpoint, my problem of 'not receiving' incoming calls born?
this is software version of cpe:
Software Version : R3.20 2006-11-17 H323 SIP FXS FXO
:noidea:
did someone else have my same problems?
thank you very much
holh-66
