[INFO] Firmware 4.02-5 (Final) für IX67 verfügbar
der_Gersthofer
Admin-Team
17 Apr 2004
Die neue Firmware 4.02 für IX67 ist nun verfügbar
Release notes:
TELEPHONE PORT FUNCTION ENHANCEMENTS
  • Improved caller ID handling
  • Improved 3-way calling voice quality
  • DTMF caller ID support for Denmark added
  • FXO caller ID improved
  • FXS2 checkboxes corrected
  • Voice packet time parameter added
  • Voice advanced page caller ID max name length corrected
  • FXS accounts come with free user licences
  • Forward to FXO port from user account no longer requires authentication
  • Optional anonymous calling from FXS ports added
SIP HANDLING IMPROVEMENTS
  • Several improvements in SIP registrar/proxy/server/B2BUA/switch
  • Authentication on multiple servers for same request improved
  • Double authentication corrected
  • Forking improved
  • "Allow outgoing calls from" improved
  • 408 request timeout fallback improved
  • Call transfer corrected
  • Cisco compatibility improved
  • Windows Messenger file transfer corrected
  • Usage of Windows Messenger on same SIP account as other SIP clients improved
OTHER ENHANCEMENTS
  • Wireless WPA2-PSK added
  • Fragment handling improved
  • Intertex enhanced provisioning system added, including continuous upgrades
  • System/Firewall/SIP-log on-page display filter
  • Saving and restoring ATAbox mode settings corrected
  • DHCP server behaviour improved when additional DHCP servers present on thenetwork
  • Flash file system integrity check added
  • PPTP magic numbers improved
  • Other minor improvements
FURTHER INFORMATION:
Flash power-on test:
The improved power-on test of the flash memory now displays "FEr" (Flash Error) if any severe error is found in the flash file system, that requires it to be reformatted. If your unit displays "FEr" after power-on, go to the upgrade firmware page and follow instructions on how to reformat your unit and reload the firmware.
aktualisierte 4.02 final-5 verfügbar
http://www.intertex.se/upfiles/67F402__.tar
IX67:
We have found a couple of minor issues after releasing 4.02 for the IX67. We have addressed them and replaced the IX67 release 4.02 available on our website with a patched version of 4.02.
If you are experiencing problems with your IX67 running release 4.02 you are recommended to get release 4.02 again from our webpage and reinstall it. The patched 4.02 calls itself "final-5" at the bottom of the system log page instead of the "final" the old unpatched 4.02 called itself.
domitrader
