[INFO] Firmware 5.10F7 für IX67
der_Gersthofer
Admin-Team
17 Apr 2004
Intertex SurfinBird IX67:
Date: 2009-APR-27 | Firmware: 5.10F7
Firmware: 5.10 date: 2009-APR-27
Release notes:
Firmware: 5.10F7 Date: 2009-APR-27
  • Security Update: Minor security problem in web server fixed
Firmware: 5.10 date: 2009-FEB-26
Release notes:
Firmware: 5.10F6 Date: 2009-FEB-26
  • Auto-upgrade improved
  • SIP registration on startup improved. Now only one registration per account is active at a time.
  • FXS username/password lengths increased to 64.
  • Removed default password for FXS (security risk).
  • SIP FENT when users are behind same NAT, setting for letting media flow directly between endpoints (not in GUI).
  • SIP FENT through b2bua improved
  • T.38 interop: SIP reuse port number when media type changes
  • SIP DID (Direct Inwards Dialing). Incoming calls can be forwarded to dynamic registration with preserved number through ";did" parameter (number/user of registration ignored)
  • Other minor improvements
Firmware: 5.10F4 Date: 2008-DEC-04
Release notes:
  • SIP FENT, Far End NAT Traversal added
  • SIP fallback via DNS redundancy corrected
  • DNS caching improved
  • Reregistration at Apply on SIP switch page improved
  • SIP/FTP on PPP connection corrected
  • SIP forward to voicemail improved
  • SIP static domain forward now support port numbers
  • SIP spoof protection improved
  • SIP "route numbers" improved
  • SIP authorization table improved
  • ARP security improved
  • SIP fallback improved
  • SIP from based routing added
  • SIP-TLS added
  • SIP support of RFC 2069 added
  • SIP selection of preferred QOP added
  • SIP Music on hold added
  • SIP B2BUA re-INVITE end-to-end added
  • SIP Strip ICE SDP attributes added
  • SIP respond 408 disable added
  • SIP keep port number added
  • Ring function on FXS ports for deaf or hearing impaired added
  • Media port number for SIP calls improved
  • Call hangup improved
  • RTSP proxy disable improved
  • RTSP unicast RTP timeout corrected
  • WLAN stability improvments
  • Voice port (FXS/FXO) improvments
  • SIP compability improvments
  • SIP stability improvments
  • Other stability improvments
Ingo2208
