[INFO] Firmware 5.11F6 für IX78
der_Gersthofer
Admin-Team
17 Apr 2004
Intertex SurfinBird IX78:​
Date: 2009-APR-14 | Firmware: 5.11F3
Firmware: 5.11F3 date: 2009-APR-14
Release notes:
  • SIP route in retransmitted ACK corrected
  • DNS recursions improved
  • Call setup delay with Aastra PBX corrected
  • SIP spirals in LANSIParator mode corrected
  • DNS recursion to authorative name servers corrected
  • Version number system modified, now also supports 'subversions' (=patches) in releases, e.g. "5.11F3"
  • MAC address cloning now also possible for ethernet WAN
  • Automatic siparator configuration corrected to support SIP spirals and spoof protection
  • route/record-route encryption/decryption corrected in SIParator mode
  • New SIP registrations now wait until previous finished
  • "WAN IP server access from inside" corrected
  • DHCP server improvements
  • Increased telephone ports password and username lengths
  • Terminating # or * not removed if timeout when calling from Telephone Ports
  • Other minor improvements
Please note that there are two different versions of the code.
  • 78A511F3.tar for networks using ADSL Annex A (normal analog telephone line)
  • 78B511F3.tar for networks using ADSL Annex B (ISDN telephone line)
Your IX78 hardware must also support the Annex used. (This firmware cannot be used in the IX66 and IX67 or IX68)
Die neue 5.11F6 ist draußen:
Firmware: 5.11F6 date: 2009-JUNE-23
Release notes:
  • Memory leaks in dhcp server and dns relay fixed
  • String objects unnecessary allocation of 1 byte fixed (sip)
  • SIP registrations was not deleted properly (memory freed when objects was reused after long time)
  • CANCEL server transaction timeout unnecessarily long
  • MEM hybrid objects used for RNG_delay_node_s (fw)
  • Memory logger improved
  • Switch to codec type used by other party did not always work (vgw)
  • FXS sent sometimes PCMA payload type instead PCMU
  • ADSL retrain improved
Thomas Max
