[INFO] Firmware 5.20F6 für IX78
der_Gersthofer
Admin-Team
17 Apr 2004
Intertex SurfinBird IX78:
Firmware: 5.20F6 date: 2010-MAY-11
Release notes:
  • SIP trunk PBX account password corrected
  • emergency number default 112 to vgw-regions file for swedish region
  • remote https access corrected
  • SIP switch page layout improved
  • Spontaneous reboot when SIP uses an invalid TCP connection corrected
  • TCP data chunks sent in wrong order or duplicated corrected
  • Hide Record-Route setting
  • Resolve public GRUU setting
  • Use software versions of AES and DES for SSL/TLS applications
  • Prioritize "incoming call matching" (SIP trunk) before "static domain forwarding"
  • Ignore invalid Replaces header, don't generate parse error
  • RIP advertises high "cost" for default route, if no WAN connection
  • Wireless was erroneously activated when saving on Network Page
Asus den vorherigen Updates
Firmware: 5.20F5 date: 2010-MAR-29
  • Prepared for future upgrades
  • Users of 5.20F4 should upgrade!
Firmware: 5.20F4 date: 2010-MAR-18
  • TR-069 improvements
  • PPP improvements
  • Config file storage improved
  • ADSL removal through branding on 5-port models corrected
  • MOS value format in call log corrected
  • Logging expired flows turned off by default
  • IX78 stability improved
  • TCP stack improved, TCP ACK flood when FIN meet on the wire
  • GUI for SIP settings "inhibit hold" and "rfc2543 hold" added
  • Checkboxes added for "allow" and "auth" in SIP authorization table
  • SIP trunk setting added for hiding record-route
  • SIP trunk setting added for showing only one "to" tag
  • SIP trunk setting added for hiding Via headers
  • Configuration files white space handling improved
  • SIP media routing after call transfer corrected
  • LAN SIParator detection of inside IP addresses improved
  • SIP URI pattern matching improved
  • Operator Sting settings improved
  • Operator TeliaFiberLAN settings improved
Firmware: 5.20F3 date: 2010-FEB-01
  • Wireless mode 802.11b/g default
  • Wireless temporary enable using SEL button corrected
  • Wireless page save & reboot improved
  • Missaligned fields on SIP Trunk page adjusted
  • USB device detection improved
  • Improved syntax for allowing only specified GUI pages to be shown for certain users
  • SIP stability when re-invite client transaction is deleted improved
  • TR-069 digest authentication corrected
  • Internal SIP UA:s now copies Record-Route to 180 responses
  • Improved manipulation capabilities of From header in SIP b2bua
  • Bootloader now supports up to 128MB SDRAM
Firmware: 5.20 date: 2009-DEC-28
  • SIP Trunking module added - See Configuration > SIP Trunk GUI page
  • Interface to management system (iEMS) added
  • Call logging with MOS score (call quality) added
  • VPN EasyServer improved
  • SIParator with ADSL as WAN now configurable
  • IP aliases now supported on all network interfaces
  • RTSP proxy support for 'destination' parameter
  • Possible to set ToS on ftp and other "flow" traffic generated by IX78 itself
  • Operator settings extended with more operator choices
  • Configuration Scheduler improved
  • DHCP server lease time settings added
  • ADSL negotiation and performance improved
  • HTTPS support for Web GUI access
  • IX78 provisioning system improved
  • TR-069 improvements (https, more objects, logging)
  • IX vendor specific TR-069 extensions, more objects added
  • SNMP setting improvements
  • IX vendor specific SNMP extensions added
  • Upgrade of software licenses (IFC) improved
  • Wireless settings reset upon upgrade
  • Wireless turned off by default
  • Wireless mode 802.11g default (not b/g mixed due to performance drawbacks)
  • Wireless MAC address changed to Intertex range
  • Wireless WPA2 encryption changed to AES
  • Wireless Cafe Mode corrected
  • Wireless iPhone and Android compatibility improved
  • Changes on wireless settings page now require reboot
SIP Improvements:
  • SIP Trunking according to RFC 4904 supported
  • SIP generic header manipulation tool using URI header syntax added
  • SIP calls with preloaded Route treated as outbound calls in call filtering
  • SIP authentication setting added to static domain forwarding table
  • SIP self-made GRUU, new option for URI encoding setting
  • SIP setting for ignoring required SIP extensions in Require and Proxy-Require header field.
  • SIP setting for anonymous call handling when using b2bua
  • SIP To header when using b2bua displays forward to URI
  • SIP setting for handling of missing Privacy header
  • SIP re-invite caused small audio glitch, now fixed
  • SIP session licenses allocated for b2bua calls improved
  • SIP session licenses counting for parallel ringing fixed
  • SIP setting to cancel all branches on 486 busy or user initiated reject added
  • SIP authorization/authentication configuration improved
  • SIP Refer-To header handling improved
  • SIP setting for not changing port number when switching to T.38 fax added
  • SIP support for Swedish characters in quoted string
  • Multiple authentication challenges for same request now supported
  • SIP log options added (methods, internal messages)
  • Do not modify SDP if "a=candidate" is present (SIP connect req.)
  • Default diffserv bits according to SIP connect and RFC 4594
SIP fixes and corrections:
  • SIP authentication when calling anonymously
  • SIP DNS SRV redundancy not working
  • Calling FENT (Far End NAT Traversal) UA through b2bua not working
  • SIP route header was not decrypted if loose route
  • Multiple registrations for same account on startup
  • SIP, cancel pending re-invite when BYE is received
  • Route header not removed in stateless ACK (2xx)
  • Remember primary server down for a 401/407 was not working for INVITE
  • Media relay was not working if offer is in response and answer in ACK
  • Switch to codec type used by other party did not always work
  • Re-INVITE for putting on hold disappear and 408 returned
  • Hanged SIP TCP connection
  • SIP B2BUA pools, use SIP account that is not busy when sharing accounts among many users
  • SIP registrations was not deleted properly (memory freed when objects was reused after long time)
  • CANCEL server transaction timeout was unnecessarily long
  • SIP Contact list in REGISTER response could contain bindings that was for another address-of-record with same username.
Webserver improvements:
  • Webserver stability improved
  • Increased number of parallel connections
  • deadlock caused by config function calls fixed
  • upgrade firmware problem fixed
Various improvements and corrections:
  • Problem with flash file system reads on startup fixed
  • Rare Ethernet driver lock-up removed
  • TCP FIN flood when closing TCP connections between IX78s
  • Long DNS host names caused buffer overflow in DNS relay
  • Ethernet driver blocked in transmit
  • PPPoE problem when setting ET4 as WAN
  • Easy server sent packets in wrong tunnels when multiple clients
  • Remote config by web problem fixed
  • Fixed bad noise when no packets received when using G.729
  • FXS/FXO voice packet time setting
  • FXS sent PCMA when Snom phone sends PCMU
  • Resolver DNS servers not being set after PPP link is up
  • IP-redirection (using Security-GUI config) did not work for TCP and UDP
  • DSA/SHA-1 certificates with SIP/TLS/openssl was not working
  • TLS firewall rule not present after first own certificate was deleted.
Please note that there are two different versions of the code.
78A520F6__.tar for networks using ADSL Annex A (normal analog telephone line)
78B520F6__.tar for networks using ADSL Annex B (ISDN telephone line)
Your IX78 hardware must also support the Annex used. (This firmware cannot be used in the IX66, IX67 or IX68)
Stepan_W
