[INFO] FW 1.0.2.9 im Downloadbereich
rsl
Aktives Mitglied
27 Mai 2004
Fuer alle Bastler auf eigenes Risiko die FW 1.0.2.9
Release Note For HT386/488/496 Firmware 1.0.2.9
Release Note For HandyTone 386/488/496 Firmware Version 1.0.2.9
July 12, 2005
Release Notes
Build 1.0.2.9
• . Fixed call waiting toggling crash and forced to use 711 issue on port1 while port2 is in alive
call(386/496)
• . Added logic to not failover to PSTN if initial boot up and FXS failover is set to Yes (488/496)
• . Enabled SYSLOG on 496, both Web UI and codes
• . Fixed of polarity reversal for 2 port models (386/496)
• . Merged fix of SIP 183 early media ignorance.(386/496/488)
• . Merged fix of SIP Info in-bound digit problem of * and # from production branch
(386/496/488)
• . 496/386 port2 off hook hears busy tone and still be able to dial out if there is a T38 session
on port1
• . 488 fixed PSTN to VOIP issues when there is a T38 session on port 1
• . Added no arp for 0 ip if static IP issue with 386/496/488
• . 386/488 added Web UI radio button for enable/disable fxs failover to PSTN.
• . Fixed CW crashes with new attempts to fix no voice (Issue 5 in report)
• . 488 added ring no answer for PSTN to VOIP call flow if there is a T38 session already in the
system
rsl
jaffpeck
