[INFO] N80: Firmware V4.0632.0.38 (Internet Edition) - nun mit SIP client, VoIP fähig
der_Gersthofer
Admin-Team
17 Apr 2004
Zwar enthält die neue Version v4.0623.0.41 v. 26-07-2006 sehr viele Verbesserungen und auch den Punkt SIP-Einstellungen gibt es (wie schon zuvor), jedoch weiterhin keinen VoIP / SIP-Client...
Improvements from v3.0617.0.6 to v4.0623.0.41
New features
* When there is a headset connected then it is possible to close the slide without ending the call
* Support for Microsoft Windows Media Player 10 has been added (No support for DRM)
* Adobe PDF Reader has been added
* Mobile Search has been added
* Antivirus has been added
* [B]This version of firmware supports FOTA (Firmware Over The Air) in some variants.[/B]
Backup
* Backup cannot read midlet when midlet is running before backup starts
* Contacts database is in use if client remains open duringbackup/restore
* Java midlet data is not restored
* Panics if java hash information was not parsed successfully
* SIS files are not restored after backup/restore
* Midlets installed to drive other than (C not backed up or restored
* Package data file restoration problem when directory doesn't alreadyexist
* Backup/Restore failed to restore assigned Speed Dial numbers
Bluetooth
* Improvements to stability of long term connections
* Switching on BT On >off> on can cause phone menu to lock up and disappear
Browser
* Browser memory usage reduction when browsing many sites
* WAP Push correction for CSL
* Remove anti-aliasing for Chinese fonts
* www.kauppalehti.fi login causes connection timed out
* Stop browser loading images when memory low
Calendar
* Meeting end date does not span correctly if user changes device timezone to greater than current value
* Received recurring vCal entry is not saved to calendar
* Calendar alarm time imported incorrectly from S40 device
* Calendar editor erases subject field if you edit a full subject field
* Calendar crashes when changing repeat rule on an entry
* The anniversary alarm never goes off
* 100 consecutive alarms does not alert
* Due date and start date are mixed in ToDo items > ToDo alarm can not be stopped
* Calendar Options>Delete entry>All entries fails to delete exceptions to recurring meetings.
* Change in time zone results in incorrect alarm date.
* System error and product freezes with certain Calendar note
* Lunar Calendar information is not available for dates before 1980
* Last instance of repeating meeting is lost, if repeating meeting is modified in Outlook
* Unable to dismiss calendar alarm
* Repeating calendar entries
Call
* Manual network selection freezes the phone if there is active PDP context
* Display wrong operator name "1" in Manual Selection list
Camera
* Bitmap corruption in thumbnails
* Camera localisation error fix (Localised Slovak) Camera: Wrong grammar form of Automatic used in Scene Set-up
Contacts
* Backslash character not properly handled when contact is copied to memory card
Data
* Call Back Access Point does not call back
* Rare Stability problems in TCP/IP
Device Manager
* Display FOTA help for FOTA enabled variants
Gallery
* Certain animated Gif files do not play when opened from Images and Videos folder
* Screen becomes black for a second right after playing video file saved in memory card
* Wrong Presentation icon is shown in the Gallery.
* BT Image Print Phone is stuck at Cancelling screen
* PictBridge/HP475 Phone hangs at cancelling screen after cancelling a pictbridge print job on HP475 printer
* Video file is not played if opening from File Manager while another is paused on the background.
* DRM image can't be zoomed in if the last right is in use.
* The display position of AnimatedGIF file is incorrect.
* New Camera Images do not appear in Gallery if Gallery is open
* The Animated GIF file, which has copyright protection of valid Consumable Rights(count=5) can be played more than 5 times.
* 3gp playback incorrect when there are many images on memory card
* No help topics available in Music Settings View.
* Issues with recognizing new mimetypes
* Localisation
* Fallback when help directory is empty
* Memory Card
* Improve FAT mount performance by increasing FAT cache granularity
* Particular 256MB MiniSD card gives "Windows was unable to complete the format" when formatting under WinXP.
* Memory card unlocking does not work if no card inserted while phone booted
* Fix for memory card missing on soft reset
Messaging
* Forwarded attachments visible as unsupported files in attachments view
* Envelope icon doesn't stop blinking until phone is rebooted
* E-mail : It takes too long to attach contacts via e-mail.
* Message stays in outbox (until rebooted) after cancelling infrared transmission
* Fixes MMS postcard image import size issue
* Obex crash with corrupted obex header
* Extra space at end of word when typing '/' character
* Can't receive message when using China Unicon dual mode card
* Add any file type to email attachment options
* Incorrect number is shown in note when fetching emails
* IMAP: Crash after trying to retrieve an email when there's no network coverage
* Message Viewer takes 39 seconds to display long unicode message
* Link Highlight in automatic find does not wrap to next line in mixed URL/number
* Data cannot be shown and deleted when save a large vCard which received by IrDA.
Multimedia
* Progressive JPEG codec doesn't compress heap after decoding
Music Player
* Music player will be terminated forcefully at the time of selecting searched data when the [Mark all] selected in track list creation.
Networking
* Sending many UDP packets results in not all packets reaching the recipient.
Real Player
* Large chunk video break up
* Unresponsive RealPlayer after streaming
Security
* No post after user cancel JAR download
* Exes are launched by Installer App before EULA is accepted
* Installer crashes when uninstalling software
* App. installed in other phone to memory card, shortcut to it is shown in test phone
* Reset loop with certain (filesystem partly corrupted) MiniSD card
* Application Manager: Application loses list of installed applications
Syncronisation
* Session ID in server notification (package #0) is not taken into use by DM client
* Synchronisation fails if entering more than 2 entries in Calendar of the handset with synchronisation setting as "None"
UPnP
* Unknown authorisation request causes media server crash.
* UPnP Apps Menu path in message for creating WLAN access points is incorrect localisation of path for all languages.
* Middle ok button does not work in result window
* Copying files with ‘&’ character in Home Network
* fix for Music playlist sharing selections not working
USB
* Mass Storage failure. Bulk Transport handles case badly
* USB mass storage class doesn't detach from Apple MAC/Tiger
Video Telephony
* UE carried no sound or image after the following procedure UE became out-of-coverage during VT communication. Then it originated
* VT after the VT disconnection.
The following changes were also included in SW release 3.0618.0.1 which was only available in some markets.
Call
* DTMF tones now allowed for emergency call created with locked phone
Applications
* RealPlayer updated – Improved handling for large chunk video break up
* RealPlayer updated – Improvements to unresponsive RealPlayer after streaming
Settings
* Settings wizard updated to week 16 release for Taiwan country Settings
SIM
* Correction to SAT polling reponse
Accessories
* Connecting doesn't succeed after disconnecting N616 car kit and from 3G to 2G
* AD15 in Music Player mode has poor sound quality (until volume changed)
hast du sie erfolgreich selber installiert?
leider scheint ja noch kein update fürs e61 im umlauf zu sein.
so long&greetz
JohnnyT
So, mit der Firmware V4.0632.0.38 ("Internet Edition") vom 13-10-2006 hat das N80 Internet Edition nun auch seinen VoIP client bekommen...
Die Product Codes für in Deutschland verkaufte original Nokias sind:
0539548 EURO 2 Patina Bronze Internet Edition
0539712 EURO 2 Pearl Black Internet Edition
Den WLAN Wizard muss man übrigens von hier nachinstallieren
Internet Radio (Streaming) kann man von hier, direkter Download von hier nachinstallieren.
Alles Weitere (wie den GIZMO VoIP client, MobiReader etc.) findet sich im Menü Internet -> Laden!
Changes/improvements made MCU SW v 4.0623.0.41 to v 4.0632.0.38:
Additional applications (market dependent)
[LIST]
[*]Adobe PDF reader (Already in N80 standard)
[*]QuickOffice (Already in N80 standard)
[*]Lifeblog (Already in N80 standard)
[*]Kodak (Already in N80 standard)
[*]Search (Already in N80 standard)
[*]Catalogs (Replaced with Download!)
[*]Anti-Virus (Already in N80 standard but moved to Download! server)
[*]Download! (New for Internet Edition)
[*]Internet Telephone (New for Internet Edition)
[*]Yahoo GO! (New for Internet Edition)
[/LIST]
Additional Services
[LIST]
[*]Online Album (market dependent)
[/LIST]
Menu structure
[LIST]
[*]New "internet" folder created and the following applications are moved/added to "Internet" folder.
[LIST]
[*]WEB
[*]Download!
[*]Search
[/LIST]
[/LIST]
New Support
[LIST]
[*]HS-69 enhancement is now supported
[/LIST]
Important changes in Video Sharing
[LIST]
[*]The addition of SIP VoIP means some changes in the SIP provisioning. The following provisioning information is needed in the OTA message otherwise Video Sharing will not work:
[/LIST]
Important information when using Backup and restore when moving to the new Software.
[LIST]
[*]When restoring a backup image from a previous release of software the 'Internet' Folder is lost and the applications are moved to the 'My Own' folder.
[/LIST]
FOTA
[LIST]
[*](Pull) is now enabled in most variants
[/LIST]
Audio
[LIST]
[*]Music Player fails to play .M4A HE-AAC file
[*]bass boost in equaliser
[/LIST]
Bluetooth
[LIST]
[*]Improved sniff mode
[*]fixes audio problems with BT headsets and carkits
[/LIST]
Browser
[LIST]
[*]Update UA Header for PR2.1
[*]Browser rendering and wrapping correction for Chinese characters
[/LIST]
Calendar
[LIST]
[*]Symbian Calendar Interim API does not accept Microsoft's Recurrence IDs
[/LIST]
Camera
[LIST]
[*]Improvements in mains frequency compensation in video mode
[*]Burst mode can take different jpeg quality
[*]Audio/video missync in recorded video
[*]Update Noise filter to improve low light handling in still images
[/LIST]
Contacts
[LIST]
[*]Voice tag issue with phonebook when adding new contacts
[/LIST]
Data
[LIST]
[*]Phone cannot find other network if you have actived PDP context
[/LIST]
Display
[LIST]
[*]Correction for miss-read of ASIC version causing pink display
[/LIST]
FOTA
[LIST]
[*]Camera forward compatibility fix for FOTA update
[*]Sync agent forward compatibility fix for FOTA update
[*]UI notifications updated for APAC region
[/LIST]
Gallery
[LIST]
[*]Change low disk warning to 2.6mb and critical threshold to 600k.
[*]Gallery crash with slide show and invalid objects
[/LIST]
Icons
[LIST]
[*]Add new Internet folder icons
[/LIST]
Localisation
[LIST]
[*]Character conversion methods work incorrectly with some Chinese characters.
[/LIST]
Memory card
[LIST]
[*]Error when encountering an unknown media with a password
[*]Cannot boot up with 2GB miniSD which formatted FAT 16 by PC
[/LIST]
Messaging
[LIST]
[*]Potential crash when re-connecting to POP3 mailbox
[*]SMS sending delay
[*]Potential crash when using always online with IMAP mailbox
[/LIST]
Operator
[LIST]
[*]Indication of the length of the MNC on a SIM
[*]Requirement based on EarlyIMS with a SIM reads IMSI from SIM but builds the private identity with wrong domain
[*]Refresh notification is not received when EF-subscribed-LAC/CI is updated on the SIM
[*]Homezone indication must not be shown during 3G PS connection/download is active
[*]Operator naming list updated to version 89
[*]Call diverts not correctly shown for line1 line2 subscription
[/LIST]
RealPlayer
[LIST]
[*]Audio Streaming problem in UAE
[/LIST]
SIM
[LIST]
[*]The SIM Server's fetch control is reset when a refresh is executed
[/LIST]
Startup
[LIST]
[*]Change default date to 1st Sept 06
[/LIST]
Video Sharing
[LIST]
[*]Change Video Sharing SIP profile default setting. (See important notes on Video Sharing at the start of this document)
[/LIST]
UPnP
[LIST]
[*]Fixes Turning Home network content sharing off forces WLAN disconnect.
[*]Fix for UPnP localisation missing strings
[/LIST]
WLAN
[LIST]
[*]Offline WLAN notification fix
[*]Registration attempt in weak WLAN fails but WLAN stays up
[/LIST]
HAllo!
Wo habt Ihr die Firmware fürs N80 her?
Nokia Service Points / Nokia Service Centers (NSC) machen Updates der Firmware (manche entbranden gegen Entgelt auch das Gerät) oder auch die Firma MPtelecom Limited aus Zweibrücken macht solche Updates bzw. entbrandet Geräte.
machen die auch das update auf die internet edition, wenn ich mit einem "normalen" N80 komme?
Musst du wohl in einem NSC deiner Wahl bzw. bei MPtelecom anrufen und nachfragen
mwsss
