[INFO] Neue Betaversion 6.0.0 für SNOM 360, SNOM 320 und SNOM 300 verfügbar
Komisch, hast du die neueste v6.0.0 RC2 installiert?
Das liegt jeweils an der Sprache, die der Webbrowser benutzt.
Das hier wurde aber noch nicht gefixt
Release 6.0.0
Update is possible from v5 only.
GUI: added XML minibrowser support (snom360)
GUI: fixed desktop SMS
GUI: title texts configurable through mass deployment (snom360)
GUI: line based ring after delay for incoming calls
GUI: changed MWI led behavior to reflect latest vmail status
GUI: fixed first dtmf echo on dialing
GUI: deny list now works for complete uri match using identity context
GUI: fixed Name+Number for numeric display names
GUI: double redial key press to redial last call
GUI: set led's for associated key events
GUI: DND icon has high priority on status line
GUI: use identity of connected call for parking/Xfer
GUI: enhanced spanish language support
GUI: reset to factory defaults restarts the phone, too
GUI: fixed speed dial on Xfer
GUI: redirection on timeout has its own target parameter now
WEB: reset to factory defaults restarts the phone, too
WEB: added new reboot info page
WEB: clean up e164 numbers dialed through web interface
WEB: added star codes based dnd/redirection
WEB: directory key is programmable
WEB: added control to filter out SIP tracing for REGISTER/SUBSCRIBE/NOTIFY
WEB: added ACTIVE option for fkey context selection
LID: adjusted knocking (call waiting) volume
LID: fixed local playback of first dtmf in handsfree mode, also fixed and cleaned overall local playback of DTMF in different cases
LID: fixed a conference bug (phone slowed down after a conference)
SIP: intercom/Push2Talk calls send an Alert-Info header
SIP: added server hosted conference feature
SIP: use display name if available in 180 Ringing
SIP: send NOTIFY on receiving an unsubscribe request
SIP: added pnp settings retrieval
Und wer ein 300er schon hat, fuer ihn ist auch was dabei. Obwohl auf den ersten Blick sieht man's nicht. ;-)
Ver 6.0 ... Funktionstaste leuchtet dauernd
So nachdem ich mein Grandstream leichten Herzens wieder verkauft habe , habe ich mir ein Snom 360 zugelegt.
Ich hatte über 2 Jahre ein Snom 200 und war ansich sehr zufrieden damit.
Das Snom 360 ist aber wirklich spitze.
Nachdem ich erstmal alles neu geupdatet hatte, auf Ver. 5.5. schnell noch die Provider eingerichtet, und schon läuft das Teil.
Nun eben meine Bemerkung zur 6.0ß ...ich habe sie auch mal eben testweise installiert ... bei mir leuchtet dann permant Funktionstaste 1 links.
War aber dann kein Problem wieder auf 5.5 dowzugraden.
Gruss aus Wien
dag74
