Install packages dynamically without firmware update?
morpheus106
10 Nov 2007
Hello,
i have install to fritz a ds-mod and now can i install other packages to web interface without recompiler firmware?
Sorry but i don't speak German
I don't understand you. You want to install a ds-mod firmware? Box? Version?
What do you want to do with "other" packages? What are "other packages"? Example?
Greets Oliver
I think I understood. You have already installed dsmod, and now you want to add packages.
Unfortunately, it is not possible to add normal packages without rebuilding the firmware and flashing it again. There are, however, ways to load packages from lan/internet servers at boot time, but this is not directly supported by dsmod (that means manual work).
Yes i have a 7170 58.04.34 AnexA_en with ds-mod.
i have any problem with compile firmware and a friends give me firmware rebuilding but now i need to add other packages (ex. openvpn and samba).
Now in my dsmod i have only package "Downloader".
Hi.
Please don't full quote posts!
Now I understand and the answer from McNetic is the only way for you. The feature of dynamic packages is not yet integrated into dsmod.
Greets Oliver
Excuse me for being so blunt, but if you have problems building DS-Mod, please learn to solve them and build your own firmwares like everybody else. It does not make much sense to just avoid problems by letting others do your work instead of solving them and learning something during the process.
Patrick89
