Ip tables ? (DS-MOD) Firmware-Version 7170 29.04.06 MPCS
Par@noid
1 Jun 2006
Starting firewall...insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.done.insmod: unresolved symbol nf_unregister_sockoptinsmod: unresolved symbol nf_register_sockoptmodprobe: failed to load module ip_tablesiptables v1.3.5: can't initialize iptables table `filter': iptables who? (do you need to insmod?)Perhaps iptables or your kernel needs to be upgraded.###########################
Wo liegt da das Problem? Ich selbst benutze Debian "Sarge" mit iptables v1.3.3 kernel -2.6.16-14-k7( 7170 29.04.06 MPCS ) Fritz.Box 7170 Schon mal danke im foraus mfg. Par@nid :confused:
[Edit Novize: [noparse]
[/noparse]-Tags eingefügt.]
Hi.
1. Benutze doch bitte Code-Tags für den Output.
2. Falscher Bereich!
2. Hast du das Image selbst erstellt?
3. Was für Iptables-Module hast du ausgewählt?
Für mich sieht das aus als wäre das ein Kernel ohne Iptables? Oder die Module fehlen?
MfG Oliver
1 . Alle klar
2 . O.K
3 . Nein image nicht selbst erstellt fertig genomen von VDR4you http://www.techni.de/dvr/index.php
4 . Was für Iptables-Module hast du ausgewählt? === wo kann ich das auswählen ??????? :confused:
5 . Und wo sind die Module ??
6 . Hab weng verständnis das ist alles neue für mich ! Danke
mfg. Par@noid
Ouou, hab mich da gerade mal angemeldet, da man da sonst nicht aufs Forum zugreifen kann. Schon klar, dass das Anbieten der modifizierten Images gegen die Lizenzbestimmungen der Firmware ist.
Mfg,
danisahne
Und jetzt ? was machen mir? :idea:
Sag uns mal welche iptables Kernel Module im /lib/modules/ Verzeichnis sind. Ist ip_tables.o da?
Danke danisahne für deine müe aber wie komm ich dort hinein ??:idea:
Mit putty (telnet oder ssh). Aber vielleicht solltest du dich besser mit dem Ersteller des Images unterhalten...
MfG Oliver
Danke für TIP ;)
( gelöst)
firewall funct :rock:
0xFaB1
