[Frage] ipt_LOG: replace printk by syslog possible?
M66B
17 Feb 2010
To get output from ipt_LOG we have to do:
echo STD_PRINTK > /dev/debug
which disables DECT too, unfortunately.
I was wondering if it is possible (will it work? disadvantages?) to replace all printk calls by syslog calls.
I don't understand your idea. The kernel doesn't do syslogd calls!? This printks are passed through klogd to the syslog.
Regards
Oliver
I am not sure how it all works, but most packages are able to write to the syslog by calling the 'regular' syslog function (the one defined in syslog.h). So I was wondering why iptables couldn't do that too. So I looked into the source of ipt_LOG and saw it was using the printk function. Maybe there are good reasons why printk is being used, like speed and thread safety, so I asked here first if somebody knows more about this.
DiamondExchangeNetwork
