Is it possible to specify which channel to be used with mISDN driver and CAPI driver
helco
17 Mrz 2009
I have a HFC ISDN card and an AVM C4 card in TE mode.
If I use "bristuff" driver for HFC card I can specify which ISDN channel to use for outgoing calls.
Is it possible to specify which channel to be used with mISDN driver for HFC card and CAPI driver for AVM C4 card?
If it is possible how to be done?
In my case I use an ISDN GSM gateways with 2 SIM cards. It's impossible to be set in gateway which SIM card to be used according to MSN number but you can set which card to work with 1st ot 2nd ISDN channel. That is the reason I am looking for this settings.
With CAPI it would be possible to choose which b-channel to use, but chan_capi does not provide this. And I don't know if the C4 card would correctly use this feature.
Armin
Thank You Armin for the answer.
What about mISDN driver for HFC card?
Is it possible to running AVM C4 card whit “bristuff” or mISDN?
No, the AVM C4 card has CAPI interface only.
Armin
IchBinEsDoch
