JFritz versus 39.04.34 firmware
mrle
29 Okt 2007
hi to all.
sorry if this already discussed here, i don't know german & don't have luck with searching in this forum.
also sorry for my bad english.
so, i have fritz.box 7140 converted in english & to annex A.
before 2 days i upgrade firmware from 39.04.26 to 39.04.34 from ftp.avm.de.
after that "Internet Usage/Monitoring" (fourth tab) in JFritz stop working.
diagram is always empty (zero KB/sec) & nothing is happening.
everything else is working OK, like before with 39.04.26 firmware.
i have JFritz_v0.6.2.04, but also trie new 0.7.0 version & everything is same.
of course i also trie both versions with new clean install, but however result is the same - "Internet Usage/Monitoring" is not working.
i am running WinXP SP2 and Java_v6 (jre1.6.0_03) on my PC.
does anybody have the same problem?
where can be the catch?
is there any medicament for this, except going back to 39.04.26 firmware in fritz.box?
thanks in advance.
the Internet Usage/Monitoring does not work with new firmwares. AVM has changed the method to receive this data and we should update our routine to make it work again.
The only thing you can do is switch back to an old firmware or wait for a new jfritz-version.
best regards,
Robert
thank you for clarify a things.
i hope that "Internet Monitoring" will work in some of next versions again.
off topic
btw. is there any trick to put fritz's web password in the url,
i mean to put in address bar of my web browser something like this:
http://fritz.box/bla-bla........pass=bla-bla/bla-bla.....
& to auto login fritz's web interface, without need to type password manually, like the JFritz is doing that?
thanks once again, and sorry for my bad english.
.... or wait for a new jfritz-version....
"Internet Usage/Monitoring" is working again with JFritz v0.7.2.
tnx to all JFritz team.
this is good news, except one bug.
green and red colour is inverted.
red is for downloading (In) & green is for uploading (Out).
btw. is there any trick to put fritz's web password in address bar of web browser, to login automatically to interface?
thanks.
hBrumann
