Junghanns octoBri und asterisk/trixbox
gregcgn
20 Nov 2006
ich habe nun endlich eine Junghanns octoBri mit Asterisk, respektive trixbox 2.0b ans laufen bekommen. Da ich aktuell nicht an den Anlagenanschluss komme, habe ich die Karte (einen Port) mit einer Arcor-NTBA verbunden. Doch tut sich nichts auf den Kanälen:
[SIZE="3"][root@asterisk1 ~]# cat /proc/zaptel/*
Span 1: ztqoz/2/1 "octoBRI PCI ISDN Card 1 Span 1 [TE] Layer 1 DEACTIVATED (F3)"
           1 ztqoz2/1/1 Clear (In use)
           2 ztqoz2/1/2 Clear (In use)
           3 ztqoz2/1/3 HDLCFCS (In use)
Span 2: ztqoz/2/2 "octoBRI PCI ISDN Card 1 Span 2 [TE] Layer 1 DEACTIVATED (F3)"
           4 ztqoz2/2/1 Clear (In use)
           5 ztqoz2/2/2 Clear (In use)
           6 ztqoz2/2/3 HDLCFCS (In use)
Span 3: ztqoz/2/3 "octoBRI PCI ISDN Card 1 Span 3 [TE] Layer 1 DEACTIVATED (F3)"
           7 ztqoz2/3/1 Clear (In use)
           8 ztqoz2/3/2 Clear (In use)
           9 ztqoz2/3/3 HDLCFCS (In use)
Span 4: ztqoz/2/4 "octoBRI PCI ISDN Card 1 Span 4 [TE] Layer 1 DEACTIVATED (F3)"
          10 ztqoz2/4/1 Clear (In use)
          11 ztqoz2/4/2 Clear (In use)
          12 ztqoz2/4/3 HDLCFCS (In use)
Span 5: ztqoz/2/5 "octoBRI PCI ISDN Card 1 Span 5 [TE] Layer 1 DEACTIVATED (F3)"
          13 ztqoz2/5/1 Clear (In use)
          14 ztqoz2/5/2 Clear (In use)
          15 ztqoz2/5/3 HDLCFCS (In use)
Span 6: ztqoz/2/6 "octoBRI PCI ISDN Card 1 Span 6 [TE] Layer 1 DEACTIVATED (F3)"
          16 ztqoz2/6/1 Clear (In use)
          17 ztqoz2/6/2 Clear (In use)
          18 ztqoz2/6/3 HDLCFCS (In use)
Span 7: ztqoz/2/7 "octoBRI PCI ISDN Card 1 Span 7 [TE] Layer 1 DEACTIVATED (F3)"
          19 ztqoz2/7/1 Clear (In use)
          20 ztqoz2/7/2 Clear (In use)
          21 ztqoz2/7/3 HDLCFCS (In use)
Span 8: ztqoz/2/8 "octoBRI PCI ISDN Card 1 Span 8 [TE] Layer 1 DEACTIVATED (F3)"
          22 ztqoz2/8/1 Clear (In use)
          23 ztqoz2/8/2 Clear (In use)
          24 ztqoz2/8/3 HDLCFCS (In use) [/SIZE]
/etc/asterisk/zapata.conf
; Zapata telephony interface
; Configuration file
[trunkgroups]
[channels]
language=de
context=from-zaptel
signalling=fxs_ks
;signalling=bri_cpe_ptmp
rxwink=300              ; Atlas seems to use long (250ms) winks
; Whether or not to do distinctive ring detection on FXO lines
;usedistinctiveringdetection=yes
usecallerid=yes
hidecallerid=no
callwaiting=yes
usecallingpres=yes
callwaitingcallerid=yes
threewaycalling=yes
transfer=yes
cancallforward=yes
callreturn=yes
echocancel=yes
echocancelwhenbridged=no
echotraining=800
rxgain=0.0
txgain=0.0
group=0
callgroup=1
pickupgroup=1
immediate=no
;faxdetect=both
faxdetect=incoming
;faxdetect=outgoing
;faxdetect=no
;Include genzaptelconf configs
#include zapata-auto.conf
group=1
;Include AMP configs
#include zapata_additional.conf
;Include BRI-HFC configs
#include zapata-BRI-HFC.conf
/etc/asterisk/zapata-BRI-HFC.conf
; Basic ISDN Card TE mode config
resetinterval=never
immediate=no
switchtype=euroisdn
pridialplan=dynamic
prilocaldialplan=local
nationalprefix=0
internationalprefix=00
usecallingpres=yes
echocancel=yes
echocancelwhenbridged=yes
echotraining=100
context=from-zaptel
group=0
channel => 1-2
channel => 4-5
channel => 7-8
channel => 10-11
channel => 13-14
channel => 16-17
channel => 19-20
channel => 22-23
Hat jemand einen Tipp für mich? Was mache ich falsch?
1000 Dank -
Gregor
bei mir läuft die karte. ich habe für jeden port eine gruppe angelegt, um sie einzeln ansprechen zu können und das läuft super.
hier mal meine zapata.conf. du kannst es ja mal versuchen.
gruss tom
[channels]
; Default language
language=de
; Default context
switchtype = euroisdn
; p2mp TE mode (for connecting ISDN lines in point-to-multipoint mode)
signalling = bri_cpe_ptmp
; p2p TE mode (for connecting ISDN lines in point-to-point mode)
;signalling = bri_cpe
; p2mp NT mode (for connecting ISDN phones in point-to-multipoint mode)
;signalling = bri_net_ptmp
; p2p NT mode (for connecting an ISDN pbx in point-to-point mode)
pridialplan = local
prilocaldialplan = dynamic
nationalprefix = 0
internationalprefix = 00
priindication = passthrough
echocancel = yes
context=from-pstn
group = 1
; S/T port 1
channel => 1-2
group = 2
; S/T port 2
channel => 4-5
group = 3
; S/T port 3
channel => 7-8
group = 4
; S/T port 4
channel => 10-11
group = 5
; S/T port 5
channel => 13-14
group = 6
; S/T port 6
channel => 16-17
group = 7
; S/T port 7
channel => 19-20
group = 8
; S/T port 8
channel => 22-23
Hallo Tom,
kannst Du Dich vielleicht noch daran erinnern, über welchen Weg Du die Karte installiert hast?
Gregor
Die OctoBri karte braucht aber soweit ich weiß die qozap-Treiber, zumindest läuft unsere hier damit.
Also brauchst du von Junghanns.net http://www.junghanns.net/downloads/bristuff-0.3.0-PRE-1y-h.tar.gz die Treiber, die dann einfach installieren.
Was auch noch ein bisschen Tricky ist, ist das Initialisieren bzw Laden des qozap-Treibers, da du da eine Bitmaske übergeben musst, die sagt welche Ports im TE bzw NT-Modus geladen werden sollen.
Install Bristuff Drivers
    The Parameter for qozap:
    Ports 1,9-12 in TE mode,Ports 2-8 in NT-Mode
    So binary coded 011111110000, thus we have to sum up
    2+4+8+16+32+64+128=254
    insmod qozap ports=254
Florian
Schaschlix69
