Kein Image möglich ab Version 10569; 7570_IAD
mister_no
27 Dez 2006
seit der Version 10569 kann ich kein Image mehr bauen. Es kommt folgende Fehlermeldung:
STEP 1: UNPACK
unpacking firmware image
Skipping 0 Bytes garbage...splitting kernel image
unpacking filesystem image
    3210 inodes (3563 blocks) to write
    created 2238 files
    created 160 directories
    created 629 symlinks
    created 343 devices
    created 0 fifos
unpacking var.tar
done.
detected firmware 7570-vDSL_en-de-fr 75.04.91 rev19965 (09.06.2011 14:27:53)
STEP 2: MODIFY
applying symlinks, deleting additional webinterfaces in: usr/www usr/www.nas
applying patches
  applying patches: 7270_v2-en (04_XX)
    applying patch file ./patches/devices/04_XX/7270/110-rc.S-mknod.patch
    patching file etc/init.d/rc.S
    applying patch file ./patches/devices/04_XX/7270/120-rc.S-dev.patch
    applying patch file ./patches/devices/04_XX/7270/130-rc.S-logging.patch
    applying patch file ./patches/devices/04_XX/7270/140-rc.S-no_avm_exit.patch
    Hunk #1 succeeded at 2090 with fuzz 2 (offset 71 lines).
  creating symlinks /tmp, /mod and /home
  creating /mnt and /opt
  setting freetz-version 'freetz-devel-10762'
  setting AVM firmware subversion 'freetz-devel-10762'
    applying patch file ./patches/scripts/100-3170_7170.sh
    applying patch file ./patches/scripts/100-7112_7170.sh
    applying patch file ./patches/scripts/100-7113_7170.sh
    applying patch file ./patches/scripts/100-7140_7170.sh
    applying patch file ./patches/scripts/100-7141_7170.sh
    applying patch file ./patches/scripts/100-7240_7270.sh
    applying patch file ./patches/scripts/100-7270v1_7270v2.sh
    applying patch file ./patches/scripts/100-7270v2_7270v1.sh
    applying patch file ./patches/scripts/100-7320_7330.sh
    applying patch file ./patches/scripts/100-7340_7390.sh
    applying patch file ./patches/scripts/100-7570_7270.sh
ERROR: no tk firmware
make: *** [firmware-nocompile] Fehler 1
In der Version wollte man wohl das Bauen eines Alien-Images von einer 7270->7570_IAD erlauben. Mein letzter Stand ist, dass ein Image mit dem neuen Kernel >xx.04.xx nicht auf der 7570 geht.
Kann sich das bitte jemand anschauen?
Danke im Voraus!
w920v alien Version auch nicht
Ein build für den Speedport W920V ist auch nicht möglich.
Das bauen für 7570 only geht aber.
mfg jpm
geht's bei Dir, wenn Du in der "Config.in" die Zeile 536 löschst?
531 config FREETZ_TYPE_7570_7270
532 bool
533 default y
534 depends on \
535 FREETZ_TYPE_7570_IAD || \
536 FREETZ_TYPE_W920V_7570 || \
537 FREETZ_TYPE_7570_7270_MENUITEM
Wenn noch immer nicht... Dann das "W920V_7570" aus der Zeile 1 aus der "/patches/scripts/100-7570_7270.sh" löschen:
isFreetzType 7570_7270 7570_IAD W920V_7570 || return 0
figo12
