Keine eingehenden Gespräche
pccorner
22 Sep 2004
vielleicht kann mir hier einer helfen.
Ausgehende Gespräche über 1und1 und Sipgate funktionieren. Intern ist auch kein Problem.
Ports sind weitergeleitet und sip_nat.conf ist angepasst.
hier die sip_nat.conf (usrnamen und pwd abgeändert)
nat=yes
externhost=xxxx.dyndns.org
localnet=192.168.178.0/255.255.255.0
externrefresh = 10
srvlookup=yes
hier die sip_additional.conf
; do not edit this file, this is an auto-generated file by freepbx
; all modifications must be done from the web gui
[1und1_97]
username=492xxxxxxx
type=friend
secret=xxxxxx
qualify=yes
nat=yes
insecure=very ; otherwise I get authentication errors
host=sip.1und1.de
fromuser=4922xxxxxx
fromdomain=sip.1und1.de
call-limit=50
[1und1_97_in]
type=friend
secret=xxxxx
nat=yes
insecure=very
host=sip.1und1.de
fromuser=49xxxxxxx
context=from-pstn
[201]
type=friend
secret=xxxxx
record_out=Adhoc
record_in=Adhoc
qualify=yes
port=5060
pickupgroup=
nat=yes
mailbox=201@device
host=dynamic
dtmfmode=rfc2833
disallow=
dial=SIP/201
context=from-internal
canreinvite=no
callgroup=
callerid=device <201>
allow=
accountcode=
call-limit=50
[202]
type=friend
secret=xxxxxx
record_out=Adhoc
record_in=Adhoc
qualify=yes
port=5060
pickupgroup=
nat=yes
mailbox=202@default
host=dynamic
dtmfmode=rfc2833
disallow=
dial=SIP/202
canreinvite=no
callgroup=
callerid=device <202>
allow=
accountcode=
call-limit=50
[203]
type=friend
secret=xxxxxx
record_out=Adhoc
record_in=Adhoc
qualify=yes
port=5060
pickupgroup=
nat=yes
mailbox=203@device
host=dynamic
dtmfmode=rfc2833
disallow=
dial=SIP/203
canreinvite=no
callgroup=
callerid=device <203>
allow=
accountcode=
call-limit=50
[sipgate_810]
username=SIP ID
type=peer
secret=NST9QW
nat=yes
insecure=very
host=sipgate.de
fromuser=SIP ID
fromdomain=sipgate.de
dtmfmode=info
disallow=all
canreinvite=no
authuser=SIP ID
allow=ulaw
allow=alaw
call-limit=50
[sipgate_810_in]
username=SIP ID
type=friend
secret=pwd
qualify=yes
insecure=very
host=sipgate.de
fromuser=SIP ID
context=from-trunk
sip show registry
Host                            Username       Refresh State                Reg.Time
sip.1und1.de:5060               4922xxx     28293 Registered           Wed, 06 Feb 2008 12:27:39
sipgate.de:5060                 xxxxx          105 Registered           Wed, 06 Feb 2008 12:53:56
sip show peers
Name/username              Host            Dyn Nat ACL Port     Status
sipgate_810_in/xxxx        217.10.79.9          N      5060     OK (26 ms)
sipgate_810/xxxx            217.10.79.9          N      5060     Unmonitored
203                             (Unspecified)    D   N      0        UNKNOWN
202/202                      192.168.178.30   D   N      5060     OK (5 ms)
201/201                      192.168.178.23   D   N      5060     OK (6 ms)
1und1_97_in                212.227.15.197       N      5060     Unmonitored
1und1_97/49xxxxxxxx    212.227.15.231       N      5060     OK (30 ms)
7 sip peers [Monitored: 4 online, 1 offline Unmonitored: 2 online, 0 offline]
Systeminfo
Trixbox v2.4.2
Kernel Version 2.6.18-53.1.4.el5 (SMP)
Distro Name  CentOS release 5 (Final)
..konntest du das Problem lösen ?
hi
Versuch mal in [1und1_97] das insecure auf invite zu setzen! hatte das gleich problem mit sipgate und das hat abhielfe geschaft!
@blauerpeti
Leider noch nicht.
@awo
Werde es ausprobieren und mich dazu melden.
hi
habe eben nochmal nachgeschaut am einfachsten geht es wenn du es über die freePBX machst undzwar unter trunks den 1und1 trunk auswählen und dann im ersten feld wo du daten einträgst da das mit insecure rein!
..ich denke mal es liegt an Trixbox.. hab jetzt mal eine Asterik 1.4 Version installiert und alles von Hand konfiguriert und eingehende anrufe funktionieren. Das wars dann wohl für mich und Trixbox
IchBinEsDoch
