- Mitglied seit
- 13 Dez 2006
- Beiträge
- 45
- Punkte für Reaktionen
- 0
- Punkte
- 6
Hello,
I have a Fritz!Box Fon Wlan 7141, firmware version 40.04.15, annex B.
I wanted to convert it to Annex A (since I live in Italy) and took a look at Haveaniceday's patch named:
fritz_as_avm_annex_a_kernel_args.tar
Such patch does NOT work on my 7141 and I also noticed that the directory /proc/avalanche/env does NOT exist.
Using telnet I found the environment directory in a different position:
/proc/sys/urlader/environment
The question is: do I have to change the script to reflect the new environment directory? Is the script I'm posting below correct?
Thanks for your help and Merry Christmas.
#! /bin/sh
INSTALL_SUCCESS_REBOOT=1
INSTALL_OTHER_ERROR=6
LED_DEVICE=/proc/led_mod/led
if [ ! -f /proc/led_mod/led ] ; then
LED_DEVICE=/var/led
echo "set led: ${LED_DEVICE}"
fi
# Power LED blinken lassen
echo "set INFO led to blink (modul=7, state=4)"
echo 7,4>${LED_DEVICE}
PROVIDER=avm
if [ ! -d /usr/www/$PROVIDER ]
then
echo 7,1>${LED_DEVICE}
/sbin/reboot &
exit $INSTALL_OTHER_ERROR
fi
# Box auf $PROVIDER setzen
echo "firmware_version $PROVIDER" > /proc/sys/urlader/environment
echo "kernel_args annex=A" > /proc/sys/urlader/environment
echo 'echo $0: done' >/var/post_install
chmod +x /var/post_install
exit $INSTALL_SUCCESS_REBOOT
