LCR nach debug.cfg Modifikation nicht mehr erreichbar
gessi2000
7 Sep 2005
ich habe auf meiner Fritz!Box Fon WLAN 7050 u.a. telnet (über das Telefon), SSH, FTP und WoLAN/WLAN aktiviert durch editieren aktiviert.
Jetzt kann ich leider meine alte LCR Installation nicht mehr erreichen über http://fritz.box/tsb.htm
Anbei meine debug.cfg Datei mit der Bitte um Hilfe was ich evtl. falsch gemacht haben könnte und wie ich den Fehler wieder beheben könnte...
export TSBcfgLast1="Sun Apr 13 11:08:54 CEST 2008"
LCR1=ENCODEDLCR_CONFIG%3Dtr%26g%2509az%2509ec%2509dw%2509em%2509b%2509eh%2509ip%2509ea%2509ga%2509hx%2509bg%2509ca%2509fh%2509es%2509ho%2509iy%2509in%2509ic%2509cf%2509gs%2509de%2509ii%2509at%2509bi%2509n%2509gp%2509ik%2509ij%2509hh%26S_kf%26%25401%26S_lb%26%25401%26S_jn%26%25401%26S_jp%26%25401%26S_il%26%25401%26LCR_SEC_OFF%261%25093%26S_hs%26%25401%26S_kz%26%25401%26S_jd%26%25401%26S_jz%26%25401%26S_jm%26%25401%26S_ji%26%25401%26S_ga%26%25402%26S_le%26%25401%26XXL%260%26S_kb%26%25401%26S_ju%26%25401%26LCR_P%260%26S_jx%26%25401%26zone%26ru%2509d%2509zg%2509e%2509ts%2509gf%2509b%2509qr%2509is%2509ct%2509gm%2509oe%2509lq%2509hp%2509ax%2509a%2509ox%2509ma%2509id%2509ff%2509om%2509fi%2509jr%2509cv%2509dp%2509dt%2509pa%2509hv%2509ee%2509cm%2509jf%2509bq%26S_kt%26%25401%26S_ko%26%25401%26VPRICE%262%26CHEAPER_TARIFF%260%26S_ku%26%25401%26TKANLAGE_BASE%26FritzBox%26S_jv%26%25401%26WELT_AUTO%261%26zone_optional%26j%2509ii%26S_im%26%25401%26LCR_MAX_TARIFFS%26100%26S_jc%26%25401%26S_js%26%25401%26PULSE_EXTRA_CHOICE%2660%252F60%26CBC_A%263%26_T%261208077515%26pMAX%265%26S_lh%26%25401%26PULSE_EXTRA%261%26S_jw%26%25401%26S_jg%26%25401%26WELT%26AF_S%2509OZ%2509M_OS%2509EU_W%2509AF_N%2509AM_N%2509EU_O%2509AS%2509AM_S%26S_jk%26%25401%26S_kw%26%25401%26CBC_A_PRICE%261.01%26VOIP%260%26S_jl%26%25401%26LCR_SEC%26Fern%2509Mobile%26S_ky%26%25401%26FALLBACK_TARIFF%26cheap%26WELT_NETZ%261%26SHOW_PRICE%26A%26CHEAPER_PRESELECT%26.1%26S_fz%26%25401%26S_jj%26%25401%26S_is%26%25401%26S_hi%26%25401%26CONNECT%26Deutsche%2520Telekom_Call%2520%2526%2520Surf%2520Comfort%2520Plus%26LCR_CALCULATE%26EXT%26S_ix%26%25401%26S_jb%26%25401%26S_hz%26%25401%26S_kx%26%25401%26VPRICEF%261.01%26S_jy%26%25401%26S_ks%26%25401%26%252B%252BSTORE%26pB1%2509S_kf%2509pTB5%2509pFB2%2509S_lb%2509S_jn%2509S_lv%2509pFTB1%2509S_jp%2509pB5%2509S_il%2509pT5%2509S_kz%2509pFB1%2509S_hs%2509S_jd%2509S_jz%2509S_jm%2509S_ji%2509S_le%2509p1%2509S_ga%2509S_kb%2509S_ju%2509pFT4%2509pT2%2509pTB3%2509pFTB4%2509pB3%2509S_jx%2509S_hm%2509S_kt%2509S_ko%2509pTB2%2509S_ku%2509S_jv%2509pFTB5%2509S_js%2509S_jc%2509pB4%2509S_im%2509S_lq%2509pTB1%2509pFB5%2509pT3%2509S_lh%2509S_jw%2509pFTB3%2509p2%2509S_jg%2509S_kw%2509S_jk%2509p3%2509pFT1%2509S_jl%2509pF3%2509pFT2%2509S_ky%2509S_fz%2509S_jj%2509S_hi%2509S_is%2509pFT5%2509S_ix%2509pF4%2509S_hz%2509p4%2509S_jb%2509S_kx%2509pF5%2509S_jy%2509S_ks%2509pT4%2509pB5pFT1%2509S_hk%2509pFB3%2509p5%2509S_ka%2509S_hp%2509S_iw%2509S_hy%2509S_io%2509pFT3%2509S_je%2509S_lg%2509S_iz%2509pF2%2509pFB4%2509pF1%2509S_kj%2509S_hu%2509S_hj%2509pB2%2509S_ln%2509S_iv%2509pT1%2509S_km%2509pTB4%2509pFTB2%26S_ka%26%25401%26S_iw%26%25401%26S_hy%26%25401%26LCR_SEC_PRICE%261.1%26S_je%26%25401%26S_io%26%25401%26LCR_TARIF_NAME%26A_T%26S_lg%26%25401%26WELT_TARIFF%26az%26S_iz%26%25401%26VORWAHL%2609901%26S_kj%26%25401%26S_hu%26%25401%26FALLBACK%26Ja%26VPRICEP%261.01%26S_iv%26%25401%26pBMAX%265%26S_km%26%25401%3B+path%3D%2Ftmpl%2Fcalc%2Ftelephone%2Flcr%2F%3Bs%3D939f5c524589761775c7be27ae4b4821%3Bid%3D010ce530fd08d48ba3a78f9ba1d58711
#FTP Service
cd /var/tmp
while !(ping -c 1 [url]www.tecchannel.de);[/url] do sleep 5; done
wget [url]http://www.tecchannel.de/download/fritz.box/bftpd.conf[/url]
wget [url]http://www.tecchannel.de/download/fritz.box/bftpd[/url]
chmod +x bftpd
chmod 777 bftpd.conf
echo "user1:abcde:0:0:root:/:null" >> /var/tmp/passwd
/var/tmp/bftpd -d -c /var/tmp/bftpd.conf
#>>FTP Service END
#>>VI,SH
mkdir /var/tmp/bin
if [ "$(busybox | grep -c ' vi,')" = "0" ];then
wget -qO /var/tmp/busybox [url]http://www.tecchannel.de/download/fritz.box/busybox[/url]
chmod +x /var/tmp/busybox
ln -s /var/tmp/busybox /var/tmp/bin/vi
ln -s /var/tmp/busybox /var/tmp/bin/sh
fi
#<<VI,SH
# newenv-script
echo "export PATH=/var/tmp/bin:$PATH" >/var/tmp/bin/newenv
echo "sh" >>/var/tmp/bin/newenv
chmod +x /var/tmp/bin/newenv
#<<SSH - Download from other site because of binary errors
cd /var/tmp
wget [url]http://mitglied.lycos.de/xyz/fritz.box/dropbearmulti[/url]
chmod +x /var/tmp/dropbearmulti
ln -s /var/tmp/dropbearmulti dropbearkey
/var/tmp/dropbearkey -t rsa -f /var/tmp/dropbear_rsa_hostkey -s 512
cp -p /var/tmp/shadow /var/tmp/tmp_shadow
sed -e "/root:/s#^root:[^:]*:#root:abcde:#" /var/tmp/tmp_shadow > /var/tmp/shadow
/var/tmp/dropbear -r /var/tmp/dropbear_rsa_hostkey
#<<Etherwake WoLAN file - obsolete because of new applet in busybox
#cd /var/tmp
#wget [url]http://mitglied.lycos.de/xyz/fritz.box/etherwake[/url]
#chmod +x /var/tmp/etherwake
#<<WoWLAN Script fuer Asus
echo "ether-wake -i eth0 00:18:DE:B8:F4:80" > /var/tmp/bin/start_mynotebook
chmod +x /var/tmp/bin/start_mynotebook
Nachtrag:
Ich bekomme folgende Fehlermeldung in einer Telnet Session:
4 13:10:01 webcm[918]: Couldn't load shared library libavmssl.so - File not found - Success (0)
May 4 13:10:32 webcm[919]: Couldn't load shared library libavmssl.so - File not found - Success (0)
May 4 13:11:03 webcm[920]: Couldn't load shared library libavmssl.so - File not found - Success (0)
May 4 13:11:34 webcm[921]: Couldn't load shared library libavmssl.so - File not found - Success (0)
May 4 13:12:05 webcm[922]: Couldn't load shared library libavmssl.so - File not found - Success (0)
Welche Prozesse sollten beim LCR denn laufen?
atrora
