Linksys spa 3000 on asterisk
vortex1
1 Mrz 2010
Hi. I am facing a small problem to configure the spa 300 to talk correctly to an asterisk installation. i do have asterisk running in a fritzbox and i would like to have a spa 3000 to get an extra line in it. i am a bit lost with the config of the asterisk regarding the spa 3000. could someone help me out over here?
Hi. I am facing a small problem to configure the spa 300 to talk correctly to an asterisk installation.?
Configuration for asterisk is easy. Make a user in your sip.conf. Send the trafic to your Spa like
exten => _X.,1,Dial(SIP/${EXTEN}@4444); 4444 is my Account for the Spa.
Incomming calls go to the context defined in your sip.conf
If you want to use the the other account of your spa for a phone you need an other user in your sip.conf.
Hi.thanks a lot for the reply.
will you be able to tell me how to interface spa on the asterisk. where do i put its ip, passwd, username,....?
solved.
thanks :cool:
Reischitz
