lsof build error
poruid
5 Aug 2007
(.... ./Configure linux)
during the build of lsof produces:
Testing C library type with /home/paul/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc ... ./lsof_Configure_tmp_26441.x: 1: Syntax error: "(" unexpected
done
Cannot determine C library type; assuming it is not glibc.
and
Testing C library for localtime() and strftime(), using /home/paul/freetz-trunk/toolchain/target/bin/mipsel-linux-uclibc-gcc ... ././lsof_Configure_tmp_26441.x: 1: Syntax error: "(" unexpected
unusable
The build completes succesfully though. Is this correct?
I looked at our commands and compared them to the one openwrt uses. Our handling is correct and better than openwrt's. ;-)
Regards
Oliver
figo12
