[Problem] Lync 2010 -> Asterisk Port 5061 Problem
Tschili
18 Mai 2010
ich habe ein Problem mit der Lync 2010 verbinden im Asterisk on FBF.
Ich habe einen
SipClient - x-light ->7701
Sipout auf Peoplephone
Lync Client -> 2001
sip.conf
[general]
context=default			; Default context for incoming calls
allowoverlap=no
; port 5060 already used by fritzbox, so use 5061
; and reconfigure local sip phones (remote sip goes through asterisk!)
; XLITE in same subnet example config (fritzbox 192.168.222.100)
; - System Settings / SIP Proxy / Default
;   - Enabled: Yes
;   - Display Name=Username=Auth. User=: 7701
;   - Password: 7701
;   - Domain/Realm: 192.168.222.100
;   - SIP Proxy: 192.168.222.100:5061
;   - Outbound Proxy: (empty)
;   - Use Outbound Proxy: Never
;   - Send Internal IP: Always
;   - Register: Default
; - Advanced System Settings / Audio / Silence Settings
;   - Transmit Silence: Yes
bindport=5061			; UDP Port to bind to (SIP standard port is 5060)
bindaddr=0.0.0.0		; IP address to bind to (0.0.0.0 binds to all)
tcpenable=yes
tcpbindaddr=0.0.0.0:5061
;tlsenable=yes                 	; tls is not enabled by default
;tlsbindaddr=0.0.0.0:5062      	; default tls port is 5061 which conflicts with
				; default fritzbox asterisk sip port 5061
srvlookup=yes			; Enable DNS SRV lookups on outbound
notifyhold = yes
calls
language=de
;using external sip provider
;and coping with dynamic ip address (the entry localnet=127...
;is required if the avm sip client is registered at localhost:5061)
;(idea taken from [email protected])
;externhost=my.dynamic.host
;localnet=127.0.0.0/255.0.0.0
;nat=yes
;canreinvite=no
;localnet=192.168.179.0/255.255.255.0
;register => bluesip/username:[email protected]/sip1
;...(http://www.ip-phone-forum.de/showpost.php?p=500468&postcount=12)
localnet=192.168.1.0/255.255.255.0
canreinvite=no
register => 90462445401:[email protected]/sip1
[7701]
context=sip7701
callerid="TestSIP 7701" <7701>
host=dynamic
domain=192.168.1.4
;nat=yes
qualify=no                     ; X-Lite is behind a NAT router
type=friend
user=7701
secret=7701
;mailbox=7701
;canreinvite=no                ; Typically set to NO if behind NAT
;regexten=1234                 ; When they register, create extension 1234
;username=xlite1
disallow=all
allow=gsm                     ; GSM consumes far less bandwidth than ulaw
allow=ulaw
allow=alaw
[Lync_Trunk]                   ; Our Lync trunk
host=192.168.1.40
type=friend
qualify=yes
transport=tcp,udp
insecure=very
port=5068
canreinvite=yes
context=from-lync
dtmfmode=rfc2833
insecure=port,invite
; sip external outgoing
[sip1_out]
type=peer
username=90462445401
fromuser=90462445401
secret=xxxxxxx
host=app1.peoplefone.ch
fromdomain=app1.peoplefone.ch
caninvite=no
canreinvite=no
nat=no
disallow=all
allow=alaw
; sip external incoming
[sip1_in]
type=peer
context=sip_in
Problem: Wenn ich einen Callout über den LyncClient mache, dann verschwindet der TCP Port 5061 LISTEN nach ca. 120 s Listen einfach. Wieso, wie kann ich das beheben
nach Neustart der FBF
netstat -l
tcp        0      0 0.0.0.0:49443           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:5060            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:5061            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:51111           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:49000           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:51112           0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:139             0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:6767            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:8080            0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN
tcp        0      0 localhost:1011          0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:23              0.0.0.0:*               LISTEN
tcp        0      0 localhost:8888          0.0.0.0:*               LISTEN
tcp        0      0 0.0.0.0:445             0.0.0.0:*               LISTEN
1. Fall Call out mit X-light (alles ok)
wenn ich einen call out mache über den X-light, dann sieht es nach 2 Minuten so aus.
netstat -l
alles ok, Port 5061 bleibt auch nach 2 Minuten bestehen
2. Fall Call out mit Lync2010 (Port 5061 nach 120s weg)
wenn ich einen call out mache über den Lync 2010, dann sieht es nach 2 Minuten so aus.
netstat -l
Port 5061 ist nach 120s weg.
Ich kann den Port nur wieder holen, wenn ich die FBF neu starte.
figo12
