[Frage] M-Net Zugangsdaten Telefonie ausgelesen - wie in FritzBox 7490 eingeben?
WolfgangN-63
14 Jun 2014
Hallo liebe Gemeinde,
ich habe - über einen kleinen Umweg - die Zugangsdaten für Telefonie meines Providers M-Net herausgefunden. Hier die (gekürzte und anonymisierte) voipcfg:
voipcfg {
        dnsport = 7077;
        rtpport_start = 7078;
        sip_srcport = 5060;
        ua1 {
                enabled = yes;
                username = "+49XXXXYYYYYYY";
                authname = "";
                passwd = "PaSsWd";
                registrar = "maxi.m-call.de";
                ttl = 30m;
                sipping_enabled = no;
                sipping_interval = 280s;
                name = "YYYYYYY";
                providername = "";
                ims_client = no;
                with_displayname = no;
                dtmfcfg = dtmfcfg_rtp_or_inband;
                rtpevent_keep_packetrate = no;
                register_failwait = 0w;
                register_failwaitmax = 30m;
                stunserver = "";
                stunserverport = 3478;
                use_internat_calling_numb = no;
                is_nat_aware = no;
                localip = 0.0.0.0;
                protocolprefer = protocolprefer_ipv6;
                ignore_received_header = no;
                always_clir = no;
                clirtype = clir_displayname;
                colptype = colp_none;
                clipnstype = clipns_off;
                vad_enabled = no;
                only_one_dialog = no;
                presence_supported = no;
                mwi_supported = no;
                mwi_inmemoria = no;
                ccbs_supported = no;
                reg_support = regsupport_auto;
                packetization = packetization_fixed;
                tx_packetsize_in_ms = 20;
                xrtp_periodic = 0;
                reject_refer = yes;
                no_register_fetch = yes;
                do_not_register = no;
                only_call_from_registrar = no;
                invite_without_register_allowed = no;
                outboundproxy = "";
                outboundproxy_without_route_header = no;
                factory_3pty_uri = "";
                no_hold_speech = no;
                dditype = ddi_none;
                ddireception = "";
                webui_trunk_id = "";
                alias_head_number = "";
                cfxsignaling = cfx_standard;
                backup_wanted = no;
                use_session_timer = no;
                use_rport = yes;
                add_rtpmap_for_all_codecs = no;
                answer_only_one_codec = no;
                without_annexb_no = no;
                srtp_supported = no;
                use_488_for_no_t38 = no;
                g726_via_rfc3551 = no;
                no_g726_32_offer_with_pt2 = no;
                g726_fixed_ptime30 = no;
                dtmf_inband_on_g711g722 = no;
                enable_3xx = yes;
                t38_reinvite_from_remote = yes;
                use_t38version0 = no;
                rtcp_xr_media_attribute = no;
                ptime_a_attribute = yes;
                tones_and_announcements_for_service = no;
                read_p_asserted_identity_header = no;
                route_always_over_internet = no;
                sipiface = sipiface_automatic;
                altc_attribute_rfc6947 = no;
                gui_readonly = yes;
                convertstate = 0;
                snmp_instance = 0;
        register_sequence_timer = 0;
        use_audiocodecs = no;
        audiocodecs = "PCMA", "PCMU", "G726-32";
        verbose = no;
        capi_blocksize_in_ms = 30;
        sip_prio = 0;
        rtp_prio = 0;
        rtcp_prio = 0;
        dyn_codecs = yes;
        prio_low_codec = no;
        send_ringtone = no;
        t38_support_enabled = no;
        t38_ignore_provider_profil = no;
        reduce_data_rate = yes;
        enum_support_enabled = no;
        bandwidth_to_leave_KBits = 0;
        dialoglimit = 0;
        enumdomains = "e164.arpa", "e164.org", "openenum.eu";
        rtpstream {
                voice_activity_detection {
                        vad_enabled = vadenabled_no;
                        vad_threshold = 10000;
                plc {
                        in_the_stack = yes;
                jitter {
                        auto_on = yes;
                        in_ms = 50;
                        in_packets = 0;
                rtcp_enabled = yes;
                silence_detection = no;
        voip_assi_enabled = no;
        voip_over_mobile = no;
        gui_readonly = no;
        voipcfg_version = 0;
// EOF
Leider bin ich unwissend genug, die Daten nicht in meine FB eingegeben zu bekommen (Schande über mich!). Ich habe so einige Eingaben versucht und auch hier im Forum gesucht.
Kann mir jemand beim Füllen der Dialoge behilflich sein?
Und falls ein hilfreicher Beitrag hier doch schon existieren sollte, dann bitte ich um Entschuldigung.
Hat sich da in 06.30 groß was geändert?
Wenn nicht, hier ne Anleitung, die zumindest unter 06.04 funktionieren sollte:
Telefonie -> Eigene Rufnummern -> Neue Rufnummer
Telefonie-Anbieter "anderer Anbieter"
Internetrufnummer "YYYYYYY" (Nummer ohne Vorwahl)
Benutzername "+49XXXXYYYYYYY"
Kennwort "PaSsWd" (das Passwort halt)
Registrar "maxi.m-call.de"
Proxy-Server leer
DTMF-Übertragung "Automatisch"
"Anbieter verwendet SIP-Trunking" aus
"Anmeldung immer über eine Internetverbindung" -> "aus" an einem M-Net-Anschluss, "an" an einem anderen DSL-Anschluss
"Ortsvorwahl für ausgehende Gespräche einfügen" an.
Dann speichern, wieder auf bearbeiten klicken und "Internettelefonie-Anbieter kontaktieren über" setzen auf "IPv4 und IPv6, IPv6 bevorzugt".
Damit sollten alle Einstellungen aus der Einstellungsdatei die du gepostet hast eingestellt sein (wenn ich keine übersehen habe).
Warum so umständlich? Du könntest doch einfach eine Konfigsicherung in der MNet Box machen und diese dann in deine 7490 importieren.
@leseratte10:
Vielen lieben Dank, das werde ich gleich mal versuchen.
@Berka:
Auch Dir herzlichen Dank! Es gibt aber genug Situationen, bei denen eine clean configuration nach einem Werksreset und/oder einer recovery per recover.exe zumindest empfohlen wird.
Du kannst ja auch nur den Telefonieteil übernehmen ;)
Hi Berka,
das habe ich gestern nach meinen vergeblichen manuellen Versuchen dann auch genau so gemacht! Nochmals vielen lieben Dank!
@leseratte10:
So, ich habe jetzt herausgefunden, warum meine manuellen Versuche nicht funktioniert haben:
Ich finde keine Eingabemöglichkeit für "protocolprefer = protocolprefer_ipv6"
Weder bei der erstmaligen Eingabe finde ich eine entsprechende Möglichkeit noch beim Editieren. Beim Bearbeiten der eigenen Rufnummer kann ich nur einen Anzeigenamen ändern.
@all:
Kann mir jemand zeigen oder sagen, wie das unter 6.30 konfiguriert werden kann?
Hm, kann man das im Nachhinein bei dir nicht einstellen?
siehe screenshoot der 7390
Genau das habe ich mir auch gedacht.
Ich habe mal ein paar Screenshots angehängt, wie das unter 6.30 auf einer 7490 aussieht.
Der Screenshot der unteren Hälfte von "Rufnummer bearbeiten", wie bei Ecki-No1, ist da aber nicht dabei.
Ich hatte vergessen zu erwähnen, dass ich zuerst eine m-net Rufnummer konfiguriert hatte, und anschließend unter Telefonie - Eigene Rufnummern - Bearbeiten auf "nur via IPv4" umstellen kann.
In diesem Punkt ist der Rufnummern-Assistent leider etwas kastriert.
Hallo liebe Boardgemeinde,
ich habe da mal eine Frage zum Auslesen der Mnet Daten da die das Passwort ja nicht rausrücken...und zwar hab ich das aktuellste Update auf meiner Fritzbox von Mnet Fritz OS 06.03...damit kann man leider nicht mehr auf Telnet zugreifen und das Passwort auslesen...jetzt meine Frage gibt es irgendeine andere Möglichkeit dieses auszulesen? Und wenn nicht funktioniert das Problemlos das man eine Sicherung erstellt und die Daten inklusive Nutzernamen und Kennwort überträgt? Würde mir nämlich gerne eine 7490 kaufen da ich das schneller WLAN 5GHZ haben möchte und einige andere Dinge?
Vielen Dank für eure Antworten schonmal!
darki
Nicht vergessen:
Die Sicherung muß mit Passwort erstellt werden, sonst klappt das nicht!
Ausserdem sollte man das Telefonbuch separat sichern.
Joe
ich bin mittlerweile mit meiner 7490 auf 6.50 gegangen - und es ist zum Mäusemelken:
Ich kann meine Telefonieeingaben immer noch nicht machen.
Ich habe (oder finde) keine Möglichkeit, über die GUI einen Eintrag der Form "protocolprefer = protocolprefer_ipv6;" zu erzeugen.
Hat jemand eine Idee?
Eventuell der letzte Punkt in der GUI: "Internettelefonie-Anbieter kontaktieren über" und dort im DropDown IPv6?
€dit. Sollte sichtbar sein unter Telefonie eigene Rufnummern bearbeiten, wenn du die Rufnummer als anderer Anbieter konfiguriert hast.
Leider habe ich dort auch keine Möglichkeit, etwas anzugeben oder auszuwählen:
Interessant ist nur, dass direkt nach dem Klick auf "Bearbeiten" einige Zeilen nach oben "weggescrollt" werden, bevor es aussieht wie folgt:
Ich werde noch ein bisschen probieren mit Fantasie-Anbietern. Wenn das nicht fruchtet, ist es Zeit für ein Ticket bei AVM ...
Der Unterschied ist der, dass du das Einrichten der Internetrufnummer immer über den Assistenten versuchst, während alle anderen dir das über das Menü zum Bearbeiten der Rufnummer zu erklären versuchen.
@KunterBunter:
Nein, ich habe immer (auch schon zu 6.30er Zeiten) folgenden Weg beschritten:
Telefonie --> Eigene Rufnummern --> Neue Rufnummer
Und ja, die erweiterte Ansicht ist eingeschaltet. :cool:
Duggy
