make load fehler
freeman111
21 Apr 2007
Hallo zusammen
Also nun bin ich auch soweit, dass ich mich ans Forum wenden muss:
Nach der Installation der HFC Karte bringt er beim make load folgende fehler:
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:510: error: 'struct zt_chan' has no member named 'bytes2receive'
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:515: error: 'struct zt_chan' has no member named 'eofrx'
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:525: error: 'struct zt_chan' has no member named 'bytes2receive'
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:531: error: 'struct zt_chan' has no member named 'bytes2receive'
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c: In function 'hfc_interrupt':
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:725: error: 'struct zt_chan' has no member named 'bytes2transmit'
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:726: error: 'struct zt_chan' has no member named 'maxbytes2transmit'
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:740: error: 'struct zt_chan' has no member named 'bytes2receive'
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:743: error: 'struct zt_chan' has no member named 'eofrx'
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:745: error: 'struct zt_chan' has no member named 'bytes2receive'
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:748: error: 'struct zt_chan' has no member named 'bytes2receive'
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:750: error: 'struct zt_chan' has no member named 'bytes2receive'
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:753: error: 'struct zt_chan' has no member named 'bytes2receive'
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:759: error: 'struct zt_chan' has no member named 'bytes2receive'
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c: In function 'zthfc_startup':
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:835: error: 'ZT_FLAG_BRIDCHAN' undeclared (first use in this function)
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:835: error: (Each undeclared identifier is reported only once
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:835: error: for each function it appears in.)
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c: In function 'hfc_findCards':
/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.c:986: warning: pointer targets in assignment differ in signedness
make[2]: *** [/usr/src/bristuff-0.3.0-PRE-1r/zaphfc/zaphfc.o] Fehler 1
make[1]: *** [_module_/usr/src/bristuff-0.3.0-PRE-1r/zaphfc] Fehler 2
make[1]: Leaving directory `/usr/src/kernel-headers-2.6.8-3-386'
make: *** [linux26] Fehler 2
Nachdem ich nun den ganzen Tag verbraten habe, :noidea: wäre ich froh, wenn mir jemand dabei helfen könnte.
Asterisk an sich scheint zu funktionieren
Habe die Installation der HFC Karte mit diesem Manual versucht:
http://wiki.ip-phone-forum.de/software:asterisk:bristuff_unter_debian
Kernel:
uname -r
2.6.8-3-386
/usr/src
asterisk-1.2.17
linux-2.6
asterisk-1.2-current.tar.gz
kernel-kbuild-2.6-3
Danke für Eure Hilfe!
Michael
Ist das noch aktuell? Wenn ich mir dein usr/src so ansehe,
habe ich das gefühl, dass du etwas viel runtergeladen/kompiliert hast...
hallo jam4ever
Ja, das ist noch aktuell.
Was meinst du, ist denn zuviel?
Gruss
freeman111
du brauchst eigentlich nur den bristuff ordner und linux-source.
setz am besten mal das system clean neu auf. gibt ja auch paar anleitungen dafür hier.
figo12
