make-Probleme
Jensen1705
27 Jul 2006
Habe nach dem HowTo gehandelt und bekomme bei make folgende Fehler
1x make
Resolving ftp.avm.de... 212.42.244.90
Connecting to ftp.avm.de|212.42.244.90|:21... connected.
Logging in as anonymous ... Logged in!
==> SYST ... done. ==> PWD ... done.
==> TYPE I ... done. ==> CWD /fritz.box/fritzbox.fon_wlan_7170
... done.
==> PASV ... done. ==> RETR fritz.box_fon_wlan_7170.29.04.06
No such file `fritz.box_fon_wlan_7170.29.04.06.image'.
Use the latest firmware fritz.box_fon_wlan_7170.29.04.15.image?
Re-run `make' for the changes to take effect.
WARNING: This configuration is probably untested!
make: *** [dl/fritz.box_fon_wlan_7170.29.04.06.image] Error 3
2xmake
z2
=> `dl/callmonitor-1.5-dsmod.tar.bz2'
Resolving download.berlios.de... 195.37.77.141
Connecting to download.berlios.de|195.37.77.141|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 288,462 (282K) [application/x-download]
100%[====================================>] 288,462 199.50K/s
10:44:38 (198.96 KB/s) - `dl/callmonitor-1.5-dsmod.tar.bz2' saved [288462/288462
STEP 1: UNPACK
unpacking firmware image
splitting kernel image
unpacking filesystem image
unpacking var.tar
done.
STEP 2: MODIFY
applying patches
make: *** [firmware] Error 2
Danke für die schnelle hilfe! Habe sowas vermutet aber nicht gefunden! Bin ja auch neu hier :p
holh-66
